Daily Driver needs Chassis advice
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Front end is worn out, looking at rebuilding/replacing most everything that wears. Namely tie rods, ball joints, bearing, seals, struts, mounting plates, engine/tranny mounts, bushing, sway bar links and brakes. I'd also like a good line on some rear shocks.
Gurus, I need part numbers and store names. Budget is >$1000.
1991 Camaro RS 3.1l
I'd like to go with lifetime warrantied parts but if the performance out weighs the warranty so be it.
Also, I've heard energy suspension carries a complete bushing kit for our fbodies, anyone have any input on this? It sounds like a cheap easy way to get around the tedious parts hunting.
1991 Camaro RS 3.1l
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Daily Driver needs Chassis advice
$1000 will almost redo it performance if desired (assuming YOU install it). I spent about $1300 on mine front and rear, using Eibach Pro-kit springs, Bilstein shocks/struts, Prothane bushings, and hard goods from NAPA. The better NAPA parts are the more expensive ones - but they are well worth the extra.
Car: 88 Camaro
Engine: L98 350
Went to NAPA and bought all four tierod ends for mine. All in identical NAPA branded boxes, three different brands of parts inside. Two from Taiwan, one from Mexico, one maybe from USA, not marked either way. I've heard that Rock Auto has Moog parts at reasonable prices, better than any parts stores imported junk I'd think.
1991 Camaro RS 3.1l
1991 Camaro RS 3.1l
