BMR subframe connector install??
Car: '84 Z28
Transmission: Turbo 350
Axle/Gears: 7.5/3.73 posi
Hi, I have a quick question about installing BMR subframe connectors (or any other brand for that matter, but will purchase the BMR's) I am wondering if it matters that I have the motor and tranny in my car prior to installing the connectors, or can I install them with the "weight" out of the car. I know I have to have the car on the ground with the weight on the tires. Thanks for the help.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: BMR subframe connector install??
the car should be completely assembled, at full weight, and the suspension loaded when you install the SFC's.
Yes what the other posters have stated is correct. You need to have the engine and tranny installed and make sure that when you weld the connectors in you have the suspension loaded. If you have any questions let me know.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
keep us updates on your progress
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
