koni struts and shocks
Old Sep 10, 2000 | 10:36 PM
blowen90ta's Avatar
planning on keeping my ws6 springs and wondering if i should go with koni reds or yellows for the best handling ride----or somthing else--am planning on getting a spoon rear torque arm at christmas but other than poly rear bushings there are no other mods!
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Sep 10, 2000 | 11:08 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Goto www.carparts.com They have the koni yellows and you can use one of those 33% off coupons to boot!
-Justin-
T-Top '86 5.0L WS6 LG4 700R4 Now Bilstein equipped
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/15/00)
There can be only one!!
Old Sep 10, 2000 | 11:09 PM
John Darragh's Avatar
It just depends on how much ride comfort you are looking for. There is an adjustment range where both the red and yellow shocks are equal in value. I recently put on a set of Koni reds and adjusted them to the firmer settings (which would also be the lower settings of the yellow shocks since they overlap). I love the way the car handles and the ride is great! I didn't want my car to ride too stiff on the freeway since I drive it to work everyday. I'm very happy with the results and would definitely buy Koni shocks again. Hope this helps.
1989 IROC Convertible, 305 TPI/Auto, KB super subs, Koni reds, BMR strut tower brace, Accel air filters, MAF screens removed - just the beginning!
Old Sep 11, 2000 | 12:12 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I used reds set to firm in the back and yellows in the front on my 87 formula. It was a great combination. Make sure you read the directions for the fronts before you install them. Likewise if you have the installed by someone else, insist they read them. The adjustment valve can be easily damaged if the directions are not followed to the letter.
Old Sep 11, 2000 | 05:31 AM
1991z281le's Avatar
The rule of thumb is to base your KONI selection on your spring rates. In your case with the firmer stock-rate WS6 springs, I'd select the KONI Reds which have enough reserve for spirited driving but won't pound your kidneys like the Yellows. Keep in mind that when you adjust either the Reds or the Yellows, you're adjusting rebound valving only.
As for the dealer, I would go with an experienced dealer, both for decent pricing but more for service and for the isolated warranty issues. My experiences with carparts.com is that they offer neither. I went with SVPU in MD--good service and good prices.
Old Sep 11, 2000 | 10:24 PM
jeremy7777's Avatar
this is for justin ,,,,,i went to the carparts website and found the koni yellows, and they are 199.00 but is that for the front pair or each , then what do i do about the back struts , ????????? allso i didnt see what coupon you were talking about were you get 33% , help ????? thanks
Old Sep 11, 2000 | 10:38 PM
Go to www.dealcatcher.com and look under the automotive section for the coupon codes to carparts.com. I recently bought my upper strut mounts from them and got $50.00 off my order.
Old Sep 12, 2000 | 05:04 AM
1991z281le's Avatar
The carparts.com coupons are good for 33% off your first purchase of $100.00 or less. The price quoted for the KONIs on their site are priced each. Savings? Not much...
Old Sep 13, 2000 | 09:18 PM
blowen90ta's Avatar
so go with the reds baised in the ws-6 springs or the ride will be unbearable?i also have been told that only the reds come with the lifetime warrenty anyone know if this is true?
Old Sep 14, 2000 | 12:34 AM
Here's my link for carparts.com coupons. http://www.amazing-bargains.com/carparts.html
Best to split up the order. Order the fronts with 1 coupon, then a seperate order for the rears with a diff coupon.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
Old Sep 14, 2000 | 04:20 AM
1991z281le's Avatar
As for the KONI warranty, either way, with both the Reds and the Yellows, there is a lifetime warranty to the original purchasing owner. For the WS6 springs, I'd use the Reds.
Old Sep 16, 2000 | 11:33 PM
Jza's Avatar
Jza
I have the reds up front, and on their firmest setting, they still seemed squishier than the old stock struts (which were blue..hehe). Right now, I have them set to the middle setting (which they call "cross country" or "touring" or something like that), and it'll handle, but that 22 mile drive to work every day sure got a lot more comfortable.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
