What is this noise?
Old Sep 17, 2000 | 09:42 PM
southerniroc's Avatar
What is this noise?
It seems like every time I hit a dip in the road I hear a noise that sounds like my right rear is bottoming out. I went to a parts store and bought some new shocks for the back, thinking they were just worn out since they were the original shocks. The noise is still there and it's driving me crazy. I dropped my gas tank and had to remove the pan hard bars(I think thats what they are called)and every since then I have heard the noise. I know I put it all back together right, so I can't understand why the noise is there. Could I have tightened the bolts to tight?
87'IROC-Z 350 TPI
Ported Plenum,Hypertech Air Foil,Ram Air kit,SLP headers,AFPR,80series flowmaster and MAF screens removed.
14.61@94mph(90+ degree weather)
Old Sep 17, 2000 | 11:32 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Check the exhaust hanger brackets and make sure they were all put back in place correctly. Also check that the rubber spring isolator bushings were put back in place on top of the rear springs. Just taking a couple of stabs in the dark. Good luck, Lon.
Old Sep 18, 2000 | 02:15 PM
JAY87GTA's Avatar
Did you check the sway bar end links? I had one break recently myself. There isn't alot of things back there. Maybe a shock lost all it's oil or something.
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
