would bad ball joints cause this problem?
Old 09-20-2000, 05:59 PM
andrew350's Avatar
When I accelerate hard or take a turn (hard or soft) my car randomly makes a horrible "creeking" noise. To me it sounds like the noise is coming from a part in a rotating assembly because the creaking will oscillate for a few yards.
I thought it was the diff, I changed all fluids.
I thought it was bushings, I replaced all w/ ployeurithane.
I thought it might be LCA's or panhard rod, so I beefed up both, nothing.
I'm running out of ideas. I recently saw a post on ball joints, and I hadn't thought of that, so I thought I'd ask.
Also, I checked the brakes and things look good. The noise isn't a squeel so much as a groan/creek.
Any help would be appriciated.
Thanks,
Andrew
Old 09-20-2000, 11:28 PM
Cosmik Debris's Avatar
Could be. When my lower ball joint failed I got a groaning soundwhen I did sharp low speed turns. You can check them by jacking up the front of the car and sticking a crow bar under the wheel and leavering it.
Another cause could be low fluid in your steering pump.
Cosmik Debris
Old 09-21-2000, 09:26 AM
andrew350's Avatar
Opps, I forgot to mention one thing. I don't think the sound is coming from the front. As a matter of fact, I'm sure its coming from the rear.
What's back there that could be making that noise??
Old 09-21-2000, 10:18 AM
ERIC'86IROC's Avatar
Axle bearings. There are no ball joints in the rear.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old 09-21-2000, 03:55 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Check your trailing arm bushings, exhaust mounts, and shock mounts.
zayne0
08-24-2015 07:22 PM
g.l.mos
08-22-2015 12:02 AM
Thirdgen89GTA
08-20-2015 03:11 PM
Newguy91rs
08-07-2015 09:51 PM
NBrehm
08-05-2015 07:57 PM
Quick Reply: would bad ball joints cause this problem?
