Question about installing Racecraft drop spindles
Old Mar 26, 2010 | 04:21 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
I am trying to install my Racecraft drop spindles and ran into a problem...
Racecraft supplies 4 aluminum spacers to use where the strut bolts onto the spindle, but I noticed while putting the bolt through the strut, spindle, and spacers, that there is still a gap between the strut and the spindle/spacers which allows the strut to move as if I need larger spacers, or washers to take up the slack.
Has anybody else run into this? I am using Koni Sport struts (Yellows).
If I torque the bolts down, do you think the gap will close up?
Attached Thumbnails Question about installing Racecraft drop spindles-cimg0054.jpg
Old Mar 26, 2010 | 05:06 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Question about installing Racecraft drop spindles
not running them but i will tell u that that gap will close right up when u hit them with an air wrench. i just changed out a bent spindal on my bird and im running KYB AGXs and they had a gap when i first installed them. that bracket is suppose to squeeze around the spindal. just hit it with an air wrench and forget about it.
Old Mar 26, 2010 | 06:26 PM
dust3r's Avatar
Thanks! I just hit it with my impact gun and the gap closed up! I just didn't remember seeing the gap with my belltech spindles, so I thought I'd ask.
Old Mar 26, 2010 | 08:22 PM
Car: 87 TA clone
no prob
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bryan623
Aug 10, 2015 11:33 AM
