Need Help Rebuilding My Front End
Old Mar 29, 2010 | 12:09 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Hello TGO,Recently on My 84 Camaro i have beening hearing a knocking noise that keeped on coming from my front suspension. This always happen when i braked, turned, etc. When i got my camaro from my father he told me that he only replace the lower control bushing in the front but he is not sure if he put them right, and that was it.My question what would you recommed to change in my camaro?I was thinking of changing the ball joints, center link, shocks, tie rod, sway bars, bushing, etcIf i change all of this parts will it be a tough job for me since i am a 20 year old kid and my knowlegde on suspension is limited.Please can someone give me some ideas on what to do.Also i do have some tools to do the job but i am not sure if they will help out I appriciate it for your help
Old Mar 30, 2010 | 10:13 AM
tarheel's Avatar
Car: Sold: 1986 Z28 Black/Silver
Engine: LG4
Transmission: 5 spd
Re: Need Help Rebuilding My Front End
I'm in the same boat...1986 camaro that makes the same sound...thinking it's time to redo the entire front suspension. Wish there was a step by step process online for our cars. I'm no mechanic, but can follow directions well.
Hopefully, some one will chime in...
Old Mar 30, 2010 | 06:32 PM
1988-305-tbi's Avatar
sounds like the balljoints need to be replaced. i'm 26 and started working on my car when i was 18/19 with no experience and nothing more than the basic tools, theese cars are very easy to learn how to work on. my guess is that if the front bushings weren't in correctly they would probably be loose and the car would be scary as hell to drive, so they're probably ok.....
Old Mar 30, 2010 | 08:33 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
O okay. So that's is were I am gonna start at with the front ball joints. Do you know if they have to be press out or can you do it easily with a hammer or something else. In fact my camaro drives alrite just the knocking noise that I am worry about.
I did replace the idle arm a while back, the old one way turning freely and that elimated one thing off the list.
Can anyone let me know if to replace the ball joints are easy or kinda hard.
Old Mar 30, 2010 | 08:37 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
theres been several posts on this just recently. try a search.
Old Mar 31, 2010 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the stickies at the top of the page as well as the following link for info that will be helpful:
https://www.thirdgen.org/forums/susp...nsion-how.html
JamesC
Old Mar 31, 2010 | 08:26 PM
you can install/remove with a BFH. but i don't recomend it, after doing it myself... autozone will loan you most tools you need for free
Old Mar 31, 2010 | 09:21 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
JamesC
Thanks James for posting the link I read it and found it very helpful. Well to be honest it showed me more then what knew of.
Thanks everyone for the help I appriciate it
Valentin
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
hectre13
Aug 26, 2015 08:17 AM
