eibach drag springs? any good? or pro kit
Old Dec 13, 2000 | 03:11 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
anyone tried the eibach drag springs?? are they any good? if not what IS good? or should i just go with the pro kit? thanks for your opinions.
Rick
Old Dec 18, 2000 | 09:29 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I have the Eibach Pro-Kit springs. But you need to decide how you plan to use your car before you decide on the suspension. Setting it up for drag racing regularly is completely differnent than for canyon carving. The drag springs are very long with a soft spring rate. It allows the car to transfer weight easily when launching at the track. However it will likely bottom easily and lean a bit more in the corners when doing high speed twisties. I prefer the improved handling the Pro-Kit provides. Good luck, Lon.
Old Dec 18, 2000 | 09:33 AM
lonsal's Avatar
I didn't notice you were local (LA CO). Post your question on our local BBS (www.sc3gfb.org). Jerry M. has the Eibach drag springs on his Z28.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
dhonda200
Aug 11, 2015 11:50 PM
