Lowering car, would my tires rub??
Old Dec 17, 2000 | 10:43 PM
AaronRS305's Avatar
The tires on my car are 245/50/16's. I just wondered if i would have any problems with them rubbing on the wheel wells or anything if i were to lower my car 1.5" or so with new springs. Im sure someone knows??
1992 Camaro RS L03
Old Dec 17, 2000 | 11:15 PM
Jeff Hauge's Avatar
I lowered my 92 2" with intrax drop springs and I dont have any problems. I am also running the same tire size.
Old Dec 17, 2000 | 11:51 PM
AaronRS305's Avatar
Where did you buy the intrax springs, and how much did they cost? Did you install them yourself?
1992 Camaro RS L03
Old Dec 18, 2000 | 08:45 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
Summit racing has the Intrax for $189.95. I've heard the Eibach springs are better. Remember you should use a high quality shock with the lowering springs. OEM shocks have trouble compensating for the reduced travel.
All the websites warn about excessive lowering. Jeff can probably give you some real world experience with his car. Would you want 2" drop springs for a daily driver? etc...
Check out my post at https://www.thirdgen.org/messgboard/...ML/000616.html
The Tech board on this site tells how to replace springs.
Hope this helps,
Craig
Old Dec 18, 2000 | 10:34 PM
Jeff Hauge's Avatar
For the first two weeks or so I loved the springs, but after that they settled a little lower. Since it is my daily driver I wish it was about 1" higher. It only scrapes if you pull into a steep driveway and dont take it at an angle. Kind of takes some getting used to. You will also need to trim the front bump stops a bit.
1992rs/ss
Jan 31, 2025 05:10 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
