Alignment
Old Apr 22, 2010 | 07:51 PM
pgh1992's Avatar
Car: '92 Camaro
Alignment
Having problems with my front steering(92 Camaro), i have had 3 alignments in the past 6 months and the car is still pulling hard to the right. No one can seem to tell me why. Any ideas?
Old Apr 22, 2010 | 08:13 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Alignment
if all is good with your front end parts , you have ckd. everything have you not ? i would have the uni-body ckd. by a frame/body shop . it may be the car was in a wreck and body twisted/bent in some way . good luck .
Old Apr 22, 2010 | 08:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Alignment
Under normal driving conditions or under braking?
JamesC
Old Apr 22, 2010 | 08:56 PM
pgh1992's Avatar
Car: '92 Camaro
Re: Alignment
under normal driving
Old Apr 22, 2010 | 10:06 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Alignment
even roads or uneven roads? and what are the alignment specs on your car (every good alignment shop should print out the specs for you on a paper, this will help us analyze problems.)
Old Apr 24, 2010 | 09:18 AM
Happy Fun Me's Avatar
Engine: T.P.I. 350
Transmission: 700r4 Auto
Re: Alignment
If all the parts and alignment are good I'd suspect the tires. Swap the fronts and see if it pulls the other way.
Old Apr 24, 2010 | 11:00 AM
UNCLE TOM's Avatar
Re: Alignment
again .
Old Apr 24, 2010 | 02:53 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: Alignment
Could be a radial pull. something like a mild slipped belt in the tire. Normally if it pulls right, it's in the right front tire, but not always. Try rotating the right side first and see if the pulling goes away. If not, then rotate the left side.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
