1LE brake swap guys, i have news...
Well, my parts arrived, and the GM "anchor plate" is in fact the same as the Guldstrand bracket. It is part number 18016034 and costs $55.54 from GMPartsDirect.com. Here are some pics of the parts.
Oooh, aluminum driveshaft too!
Dont forget to buy the bolts and washers when you place your order. PN's 10268875, 11508133, and 14084051. 4 of each required.
-Jason M. 1991 Camaro Z28
"Shampoo is better, I go on first and clean the hair."
[This message has been edited by Jason M 91Z (edited December 09, 2000).]
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Thats great news...
thanks for the part numbers on the bolts and washers. I could kick myself for throwing away the spindles from my 91. I could have set it up and just bolted them on.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
Great Stuff.
Now, bolt it on, and THROW OUT THE ANCHOR!
What kind of brake pads are you going to use? Performance Friction has the Z-rated pad, great for serious street duty, and Hawk has the HP-Plus. Either of these will be a great pad.
Keep us posted on your progress.
Oh and please excuse me for this but I have to add an "I told ya so" cause I was right about the brackets and spindles and stuff, so I TOLD YA SO! sorry.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
[This message has been edited by Hunter Motorsports (edited December 09, 2000).]
Karl Hunter
Hunter Motorsports
Yeah Karl you were definetly right! From what I see, I have to drill and tap two holes on the spindles to 1/2"-16? Other than that and cutting the caliper ears off, no other modifications to the spindle are necessary right?
I'm using Autospecialty Metal-Lux pads. They're supposedly low dust and squeal. I'm using Autospecialty rotors too so we'll see how they work out. If I'm not satisfied with them I'll probably just go for Pagid or PFC. Most of my driving is spirited street, so I don't want to sacrifice cold performance for a pad that bites like Mike Tyson when they're hot. Every once in a while I'll have to bring the car down from 100 into a quick off ramp, but other than that it doesn't get beat too hard. Thanks for the help and advice!
I would double check the bolts you have because most of the bolts on our cars is metric. I order the same parts as you did and i believethe two center bolts are 14mm-1.75 pitch and the two outer blots are 12mm-1.75 pitch. I do have a ? for you how does the cradle mount to the anchor? does the anchor go to the inside or outside of the cradle?
Tad,
You're right, they are metric bolts. I had to think twice myself.
The anchor plate bolts to the spindle and when you put the rotor on, it actually goes over the anchor plate a bit. On the backside of the rotor, there is a void between the hub and the friction surface, and the anchor plate sits about 1/4" into the void. Once the rotor is installed and bearings adjusted, the cradle installs over the rotor and attatches to the back side of the anchor plate (towards the engine bay). The center two holes on the anchor plate are threaded and the bolts go through the cradle and into the anchor plate.
When you get the parts and mock everything up, you'll see that the cradle can only go on one way. Basically the only thing that can possibly be screwed up is that the anchor plate could be installed backwards. But when you see it you'll note the little protrusions on the backside that contact the spindle and cradle. When installed, the anchor plate will have the part numbers facing outwards. HTH.
thats good news and a good time to update Pauls Tech article to include this info
The article is pretty good I followed it and found two problems: the source for brackets and the Brake hose bolt PN is 10286122- its called a fitting (its just a banjo bolt), cost $2.45
heres the article- http://www.isthq.com/~dan/1LEbrake.html
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
CAn you list the parts and the prices so I can get a idea of what it is going to cost, thanks alot joe
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: 90 IROC
Engine: 406
This information Would make a great tech articule for this website!
[This message has been edited by MikeH (edited December 12, 2000).]
Well guys, I probably won't get around to the retrofit for at least a month, but I'm willing to document my work and take pictures to make an article with. Hopefully I can submit it to Dirk and we can get it on the site sometime. Thanks for all the help everyone.
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have attemted to install the GM bracket on my stock (non 1LE) spindles. And it would not bolt up. without some drilling and taaping,as you have mentioned.But! I believe the "GULDSTRAND" brackets do not require any drilling or tapping of the spindles. I believe that for the money and to save all the extra hassle. The guldstrand brackets are a better deal.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side not too bad
Engine: 5.0 TPI
You HAVE TO drill and tap.
Those dinky little bolts that normally hold the dust shield/backing plate to the spindle are not nearly strong enough to handle the forces of braking. If the gulstrand brackets do indeed use the small bolts then I would never put them on anyway for fear of death.
Buy a drill bit and a tap of the correct size and do it right. It will take less than 10 minutes to do both spindles and you will have the peace of mind knowing that it will not fall apart the first time you jump on the brakes.
Karl Hunter
Hunter Motorsports
Karl Hunter
Hunter Motorsports
Car: 90 IROC
Engine: 406
I agree..the Guldstrand brackets would have to be drilled and tapped as well.
I had heard the Guildstrand brackets were no longer available. How were you going to get them????
Jim
1992 Z28 116K miles - early mods: airfoil, plug wires, ADS chip, Flowmaster muffler
Current mods: Edelbrock intake, Accel AFR, SLP Siamese Runners
Future mods: ??????
Jim
Future mods: ??????
It may be slightly off the topic, but does converting to 1-LE front brakes this way still move the tires out? I would like to convert mine, but my wheel and tire combo slightly scrapes the outside of the wheel-wells now! Don't want to change rims and tires.
I believe that somebody else has addressed this question and they decided that it did not relocate the wheel appreciably....
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front
23mm sta. bar in rear
rear lowered 1" by cutting 1 1/4 coils of '84Z28 springs
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
'84Z28/'92 305TPI
MAT relocated
Love this engine!
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
