Blown monroe sensa trac shocks? after 15k?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
MY car is lowered 2" I put brand new monroes on at the time. They are about a year or so old less then 15k on them. I've been hearing a popping sound when the car goes up on slopes and then back down. So I took a look underneath and the shock had signs of leakage all over the place. The other side is the same just not as bad. Is this common?
Re: Blown monroe sensa trac shocks? after 15k?
I just exchanged a pair of Monroe Sensa-Trak shocks from my truck, they blew after less than 1 year of use. Had fluid leakage as you describe.
For my thirdgen, I've had Edelbrock shocks on the back since 2003 and they're great. The dynamic valving helps keep the rear planted on rough pavement but still hook during hard cornering.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm certainly no expert, but it could be. You have all this nice stuff in the car - I see Spohn, Edelbrock Elite, Hooker, and custom this and that - and then you install the cheapest shocks available? Especially with it lowered so much - not sure any Monroe shock was ever designed to really work at all, let alone work with a changed geometry. Might be a simple case of "you got what you paid for". I dunno - see what others say.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the sensacraps and crap, and not good for a lowered application, that why they blew out so fast.
Car: 87 ls1 camaro 510 rwhp
Engine: 2002 ls1 cam carb and juice
Axle/Gears: 4.10
i tried sensacraps on mine too, one wheel hop and they're done. got tired of taking them back for new ones after a month.
Car: 91' bird(WS6>>305TBI), 82'Regal
And I was gonna start a thread asking about "Monroe Sensa-Trac". Thanks to this thread I won't have to waste my time..... So what is the solution for 70 -100 bucks?
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I have them on my truck and one of the front shocks blew out after a few months. So far the replacement one has been fine. I have them on my Firebird and so far no problems..Hope it stays that way.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You need good shocks to handle the spring rates of a lowered car in most cases. Stiff springs torture shocks.
KYB's are prob the best bet for cheap, but there are a couple of other good options I think. Konis are great but $$$$$. Konis can outlast the cars they're mounted on.
Lol if I recall correctly the box states " Check every 12k miles" And as many have stated they arent designed for sustained use on lowered applications. Lowering the center of gravity changes the dynamics of how the shocks were design to absorb impacts. Thread
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
