Shaking at 85mph?
Old Dec 29, 2000 | 11:01 AM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Shaking at 85mph?
I have a 1988 GTA with 30,000 miles on it, along with the original tires. Whenver I go 85mph or higher the car shakes. The whole dash shakes and the sunvisor falls down also. The tires are about shot and I'm getting some new Goodyear Eagle HP 245/50/16 with a four wheel alignment and the tires balanced, will that take that shake away? Thanks to all who reply.
1988 GTA:
Crane Cam, K&N,
Flowmaster, Off Road Pipe.
Old Dec 29, 2000 | 12:14 PM
Blade's Avatar
Well do that first and find out. Most then likely it will.
Old Jan 2, 2001 | 03:26 PM
Kenn's Avatar
Its the stock driveshaft not balanced to spin that fast - mine use to do that at 80mph many many many mods ago
Old Jan 3, 2001 | 12:06 PM
Blade's Avatar
What ?!? LOL If your car shakes at 80 mph it's certainly NOT because GM designed it that way. lol
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 3, 2001 | 12:13 PM
91' Camaro Man's Avatar
The stock drive shafts have the history of shaking like a wet dog in the arctic at speeds around 70-80 and up. I say who cares! I'm usually not going that fast anyways.
Love you Camaro, love your wife/girlfriend, BUT ALWAYS PUT GOD FIRST!!!
1991 LO3 305 RS Camaro w/Headman headers and custom dual exaust.
Old Jan 4, 2001 | 09:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you discover that the drive shaft is causing the problem and wish to up-grade, I have two thirdgen alum shafts. See my ad in the classifieds.
JamesC
Old Jan 7, 2001 | 12:22 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Mine did that shake. The front tires were out of round.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Jan 11, 2001 | 09:52 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
the vibration is undoubtedly due to a tire with a broken belt. Later!
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side not too bad
Old Jan 12, 2001 | 08:56 AM
1BADAZTA's Avatar
Does the shaking only do it at 85 mph or all the time? And does the steering wheel shake? If the steering wheel shakes, then it's a bad balance on one or both of the front tires, not a broken belt in the tire. If there was a broken belt then you would be hearing a thumping noise and you'd be shaking at all speeds. Good luck!
88'TA 305TPI 330HP, NATURALLY ASPIRATED, PASSES N.J. EMMISIONS. "I AM JUST THAT GOOD"
Old Jan 12, 2001 | 09:50 AM
88IROCARMY's Avatar
Check the idler arm or replace it . This item will cause shaking of the front and steering wheel when it wears out. My was a recent replacement but unknowlingly the grease fitting fell out and I was getting the shakes..
Old Jan 13, 2001 | 04:08 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Check the sway bar links, especially in the rear. They tend to break pretty easily. My car did the same thing and after i replace my sway bar link in the rear (one was missing) the car drives smooth at 110 mph.
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:120,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph before gears
Old Jan 14, 2001 | 05:45 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Check the tires first. I have a checklist for vebrations that I got out of a magazine once. Numerous things can cause bad vibes. No use spending all your money when it can be fixed easily. I had a similar problem and I was thinking of doing all the things already posted. Instead, I started by checking to make sure all the bolts and fasteners were tight and went from there. It ended up that all I needed was a tire balancing. But don't tell my wife, I used it as an excuse to get new springs (she knows nothing about cars).
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Old Jan 14, 2001 | 05:47 PM
Old Jan 15, 2001 | 12:32 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
The tires were just shot and that's what the problem was. I put on 4 new goodyear hp 245/50/16 with a four wheel alignment and balance. I coudn't beleive how much smoother it rode at high speeds. The other tires were so shot that with these new tires i think i knocked off a half sec. in the quater. lol.
1988 GTA (29,000 original miles):
Crane Cam, K&N
Old Jan 18, 2001 | 06:23 AM
untchbl88's Avatar
i had the same thing happen to me. someone refered to it as the "death wobble". they said that it was the driveshaft being unbalenced. i changed the tires on my vehicle and it took the shakes away without having to change the shaft
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
xxx3man`
Sep 23, 2015 10:37 PM
88rscamar0
Sep 23, 2015 09:08 PM
Amillionoh7
Sep 5, 2015 11:44 PM
