Cutting the springs or suspension kits?!?!?
Car: 2003 SVT Mustang Cobra
Engine: 4.6L DOHC Supercharged
Axle/Gears: 3.55
Hi, I really need to lower my T/A because it looks silly. There is so much room between the tire and the wheel-well and I don't like it. I would like to know if a suspesion kit is in order or can I simply cut the springs.
It's all fun and games 'till someone looses an eye....then it's fun yu can't see!!
1987 Pontiac Trans Am
-305 cid motor (soon to be gone)
-Flowmaster Muffler
-Yokohama Tires
-3" Exhaust Tips
-180 degree Thermostat
-JVC Head Unit w/ Kicker subs!
-Flowmaster Muffler
-Yokohama Tires
-3" Exhaust Tips
Car: 86' Z28
Engine: 355
you could cut your springs, but it will throw off the geometry of the front end. your best bet would be to buy lowering spindles for the front and lowering springs for the back. You could chop the back ones, and it shouldnt hurt anything to bad, but the lowering springs arent that expensive, so if you have a little extra cash, you should do it the right way.
86 Z28 red,
originally LG4,
new 350,
non comp Qjet,
T-5 five speed with new clutch,
stock 3.23 gears,
K&N Air Filter (best 35 bucks i ever spent!)
Edelbrock Performer intake,
crane 272H cam,
Accel 8mm wires,
Edelbrock performer cat- back,
Homemade cold/forced air intake.
KYB GR-2 struts and shocks.
Grant GT leather wrap steering wheel.
Sony X-plod stereo.
Optima 6x9's
Future mods:
NOS, Edelbrock TES headers, hi flo cat., 4th gen interior, 6 point roll cage, 3.42 gears
hurst billet/plus shifter, Edelbrock STB, IROC Rims
view my car
[This message has been edited by zupmanZ28 (edited January 28, 2001).]
86 Z28 red,
originally LG4,
new 350,
non comp Qjet,
stock 3.23 gears,
crane 272H cam,
Accel 8mm wires,
Sony X-plod stereo.
Optima 6x9's
Future mods:
view my car
Car: '85 IROC
Yes, lowering will change the geometry, but it will *improve* it by allowing some negative camber, which is hard to get on a 3rd gen. Cutting the springs will also stiffen them, which is also good to keep from bottoming. The trick is to cut the right amount. Remember, the spring is about half way between the wheel and the control arm pivot point, so the car will drop twice as much as you would at first expect. No amount of cutting will bring it up again.
Use a cutoff wheel, not a torch, and start out with no more than 1/2 a coil. Both ends of the front springs are square, but one end is more "open" than the other. That is the end to cut and keep them the same way up.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Use a cutoff wheel, not a torch, and start out with no more than 1/2 a coil. Both ends of the front springs are square, but one end is more "open" than the other. That is the end to cut and keep them the same way up.------------------
Dialed_In
Aug 20, 2015 01:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TA8487
Aug 11, 2015 09:02 PM
