Various engine mount bolt sizes
Old May 11, 2010 | 02:12 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
i had a gm rubber clamshell motor mount, a 5" long 7/16" bolt fit through. THe engine bracket can fit up to a 9/16" bolt. The bracket on the motor and the clamshell and the 5" bolts are stock. I put in the new polyurethane inserts into the clamshell. the 7/16" factory bolt wobbles around in there alot. i tried a 1/2" and 9/16" bolt and they dont really make it all the way through the poly inserts. the outer part of the poly inserts are 9/16" but the middle is smaller. advise?
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
knight72
Aug 10, 2015 09:32 PM
Elliswon
Aug 10, 2015 12:33 PM
