Brake maintenance for 89 Formula
Old Feb 19, 2001 | 05:13 PM
Adam89F's Avatar
Hey. I'm planning on a front brake job.
I want to keep the car with as close to original parts as I can.
I am concerned because with the front wheels off, I see that the pads are touching the rotor. Should this be? Does this go away once the car is started and the brake system becomes pressurized? I see this as being a source of brake drag.
What brand of brake pads should I get?
Location would be great from fellow Candaians.
I take it that I have a Floating Caliper.
I've attempted to remove the bottom pin using a hex head on my wrench...no luck. Besides jacking the car up higher and getting underheath it to get more force behind the wrench, what can I do?
What should I use to clean the caliper's exterior and the brake hoses? How do I know if I should be replacing them too?
Thanks.
Dale Earnhardt was is a legend.
Old Feb 19, 2001 | 06:57 PM
ede's Avatar
ede
there is nothing to make the pads retract, so they ride aginst the rotors. the calipers have bushings that the bolts go through that ride in a plastic o ring sort of thing, this allows the calipers to move a small amount and that keep the pads from truely draging o nthe rotor, unless you have problems.
ICON Motorsports
1st & 3rd
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
lt1z350
Aug 28, 2015 05:57 AM
theshackle
Aug 22, 2015 06:52 PM
JFry
Aug 19, 2015 01:25 PM
