adj. lca. vs non adj. lca.
Old May 24, 2010 | 08:13 AM
camedout camaro's Avatar
i have never done any thing with a cars suspention but i was told that if i change my lca it will reduce my wheel hop. this is a budget build and was wondering if it was worth it to go adjustable or get the non-adjustable? thanks for the help.
Old May 24, 2010 | 10:25 AM
UMI Sales's Avatar
Re: adj. lca. vs non adj. lca.
Hello
Yes going with a set of LCA's will help eliminate wheel hop issues. But before I am able to give you a good recommendation for a LCA. I am going to need to know what your plans are for the vehicle. UMI Performance offers a wide variety of LCA's that I am sure will met your needs. Below is a link to show you what all we have to offer!
http://www.umiperformance.com/catalo...slk9gmff3d6aq7
If you have any other questions feel free to ask.
Brad
Old May 24, 2010 | 12:25 PM
anthony714's Avatar
btw,good luck,ive tried it all to rid myself of wheel hop and no luck.thinking of selling the car and going back to my good old fashioned ford mustang with leaf springs.......
Old May 25, 2010 | 11:49 AM
yea i was looking at some umi lca. my plans with the car is to make a mild street car. like i said this is my first build and the car is kinda junky not wanting to drop big money into it. it would take to much to fix it up then its worth but the drive train i am going to transplant into somthing else. so for now untl i save for another track car or b.a street car. so if i can put as little money into the frame as possable i will go with the cheaper route. i was just wondering if there was a big proformance jump for the non adj. to the adj. lca. tnx for the help
Old May 25, 2010 | 02:52 PM
UMI Sales's Avatar
Hello
What the difference in the nonadjustable and the adjustable LCA's. What the benefits about a adjustable over a non is if you ever decide to run a aftermarket wheel or a drag radial/slick. They will allow you to center the wheel in the wheel well. And if you go with a rod end or a roto joint then it will also eliminate any binding issues. But if you never plan on doing so then you will be just fine with the non adjustable. If you have any other questions feel free to ask.
Brad
Hecubus
Dec 6, 2001 12:13 PM
Killer-Z
Aftermarket Product Review
Nov 5, 2001 09:10 PM
camarojoe
May 15, 2001 11:03 PM
Mark 89Formula
Sep 11, 2000 06:33 PM
