HELP PLEASE!!!!
Old Feb 20, 2001 | 08:16 AM
mustangs killer's Avatar
HELP PLEASE!!!!
I have a 91 RS Camaro and almost every time I mash the gas instead of the tires sticking to the road or spining the bouce and leave a dotted black marks. The marks are cool tooking but it is driving me crazy. how can i get my tires to stick to the ground or at least kept them from hopping. has anyone else had this prob. thanks
Old Feb 20, 2001 | 11:02 AM
Blue92's Avatar
get a posi rear and steve spohn lca's. My RS hooks smooth with these parts, and the posi rear I got is only a 2.73. That single wheel spin is crazy for sports car, whoever decided to make rears like that were insane.
http://albums.photopoint.com/j/View?...781&p=29492901 http://albums.photopoint.com/j/View?...781&p=29492902 http://albums.photopoint.com/j/View?...781&p=29495767
"DriveHarder"
Stock 305TBI,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Old Feb 20, 2001 | 02:23 PM
I already have a posi rearend. and aulburn 3.73 posi unit. but thanks for the suggestion
Old Feb 20, 2001 | 11:39 PM
25th anniversarry RS's Avatar
what condition are your springs and shocks in? Put the car on a hoist or jack it up with the rear hanging and inspect the rear control arms and bushings.
Old Feb 20, 2001 | 11:56 PM
Would bad shocks and springs cause wheel hop.
Old Feb 21, 2001 | 02:03 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Bad shocks will with out a doubt, make the rear hop. Shocks add dampening. If you didn't have them, the car would never stop bouncing.
Also, if the shocks are too stiff, you won't be able to keep the tires on the ground. There won't be any cushioning.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 21, 2001 | 09:38 AM
so can i go to the junkyard and get a the rear suspension from a Z28 or a Iroc Z. What years will fit under my 91 RS
Old Feb 21, 2001 | 10:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You dont' want to get rear shocks from a junkyard, do you? They'd be junk... and for the same price (including time & effort to remove them from the junked car), you can get new ones.
When I did my friend's 1991 Formula's exhaust in 1995, his shocks were so shot that I could compress them without any effort. I'm sure if you have the original shocks on the car, yours are shot by now.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 21, 2001 | 11:37 AM
nestz28's Avatar
Really the best way to deal with the wheelhop would be to just get some good new shocks and aftermarket control arms. Swapping in the suspension from a IROC or Z28 would just give you stiffer springs (which can help wheelhop) and a bigger sway bar. The springs are a really easy swap, so try that and some new shocks and see if it helps. Then try some new control arms if it doesn't. Hope this helps.
Old Feb 21, 2001 | 12:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh yeah, aren't those Lakewood control arms only $60 or so for a set? That's as budget as you can get
