can drum to disc be done without
Old Feb 21, 2001 | 12:32 AM
ScreaminDeamin85Z's Avatar
can it be done without changing the rear end? i have an 89 iroc and want it to be disc rear so that when i put the 17's on it doesnt look bad with the rusted colored drums.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
http://users.argolink.net/bvana/
http://ScreaminDeamin.cz28.com
[This message has been edited by ScreaminDeamin85Z (edited February 20, 2001).]
Old Feb 21, 2001 | 10:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Nope... well, at least, not without some heavy duty (and very strong) welding:
At the ends of the drum axle tubes are rectangular plates with a hole in the top for the brake line.
At the ends of the disc axle tubes are squares.
On the "difficulty level" of things, swapping the axle housings themselves isn't bad, if you haven't done any axle work before, it would take you a day. Switching to a disc brake system is worse...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 21, 2001 | 02:27 PM
so "if" i could get the axle housings and sawp them onto my rearend housing, then i could put discs on?
Brandon
New project-89 IROC
Old Feb 21, 2001 | 03:16 PM
Tad's Avatar
Tad
Yes it can be done without changing the rear end. My brother in law use the backing plates off my 87 rearend(disc brakes). All he did was cut part of the flange just above the large hole on top. The bottom two holes line up with the backing plate but have to drill out to the same size as the backing plate holes.Then mount the plate on and drill out the two top holes.
Old Feb 21, 2001 | 03:57 PM
Blue92's Avatar
Or you can always buy the bear kit for some $$$. They have a drum to disc conversion kit.
Old Feb 21, 2001 | 09:46 PM
well how much does the bear kit cost?
Brandon
New project-89 IROC
Old Feb 22, 2001 | 12:19 PM
ttt
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
