Spohn K member and A arms installation review.
Old May 27, 2010 | 04:26 AM
87350IROC's Avatar
Car: 87' IROC
I just got my Spohn K-member and A-arms installed last weekend and I thought I'd share my experiences with you guys. I got the k-member with spring pockets and mounts for the k-member braces. The a-arms are the del-sphere jointed arms with spring pockets. First of all some pics.
Old May 27, 2010 | 04:33 AM
87350IROC's Avatar
Car: 87' IROC
Re: Spohn K member and A arms installation review.
The k-member installed pretty easily. The holes all lined up nicely. The only problem I ran into was the passenger side k-member brace mount. The inside corner made contact with the stock oil cooler lines and prevented the k-member from fully installing. I was able to trim off the corner with a dremel and all fits well now. I imagine Spohn didn't have an oil cooler equipt car when they were designing this thing. No big deal. Its amazing how much room there is both for engine maintenance and exhaust and oil pan clearance.
The a-arms were also fairly easy to install. The only problem I ran into was the bushings were not as wide as the flanges on the k-member. They are about 1/8" narrower. I'm not sure whether it was the k-member or the a-arms that were off. When the bolts were tightened the k-member would bend enough to take up the 1/8" but I am not comfortable with that, as the k-member was bending on a welded joint. So instead I added some hardened washers to take up the gap. It should work out fine.
I'll add some pics of the spacers later.
Old May 27, 2010 | 03:50 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You get the weight jacks from Spohn too?
Old May 27, 2010 | 05:47 PM
87350IROC's Avatar
Car: 87' IROC
Nope. They are from Ground Control.
Old May 28, 2010 | 01:49 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
doing this also in a few days. have all the parts & coil overs.
going to see about taking all the factry K member and A arms out in 1 unit.
Old May 28, 2010 | 02:00 AM
Shadow Z's Avatar
Car: Lots of 'em
Wow man, that's an awesome setup you've got there. Looks clean.
Old May 28, 2010 | 10:05 AM
87350IROC's Avatar
Car: 87' IROC
Oh, one more thing to add. I found that the cotter pin holes in the ball joints were drilled to high. I had to shim the castle nut up with 2 hardened washers on the passenger side and one on the drivers side. I don't think this is a big deal, but its something to keep an eye on.
Now for the difference between the driver and passenger side. I measured the spindles and found that the spindle on the drivers side was 0.10" ticker than the passenger side at the ball joint stud hole. These spindles are part of an ebmiller brake kit. I measured my old spindles and found both to be the thicker version. I'm guess at some point from 82-92 GM either thickened or thinned the spindles and this area and probably just retained the part number. Either way I'm not to worried about it.
Old May 28, 2010 | 10:10 AM
87350IROC's Avatar
Car: 87' IROC
Here you can see the shimmed castle nut.
Old May 28, 2010 | 12:40 PM
Shadow Z's Avatar
Car: Lots of 'em
I'm going completely off topic, but what camera do you use? The color in them pictures was pretty amazing, like watching HDTV, because I'm used to my cheap digital camera from like 2006.
Old May 28, 2010 | 12:50 PM
87350IROC's Avatar
Car: 87' IROC
Thanks Shadow. Photography is another hobby of mine. I use a Nikon D40. Its digital SLR camera. Pretty bulky but the image quality is worth it. One tip, avoid using flash if you can help it. It has a tendency to wash out colors.
Old May 28, 2010 | 02:48 PM
87350IROC's Avatar
Car: 87' IROC
This may be a bit challenging. You will need to be careful that the springs don't pop out of the a-arms when you are lowering them. It was not very time consuming to take the a-arms out of the k-member first.
Old May 29, 2010 | 09:33 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
looks good. What calipers are those?
Old May 29, 2010 | 10:34 AM
87350IROC's Avatar
Car: 87' IROC
They are Wilwood FSL calipers. Part of Ed Miller's Wilwood kit.
Old Jun 1, 2010 | 02:20 PM
1Aauto's Avatar
Former Sponsor
Great looking setup
Old Jun 1, 2010 | 03:08 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Very nice, hope to get that far one day.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
IROCZ1989
Aug 19, 2015 08:15 AM
