STB for carb and drivers side air...
Old Feb 25, 2001 | 07:20 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
Does anybody make a brace that works with carbed cars with the airconditioner on the drivers side. I've heard that the edelbrock unit hits the airconditioner bracket. Thanks
Old Feb 26, 2001 | 05:04 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have the edelbrock one and it only took miner moding to make work. I would do it again.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Feb 26, 2001 | 09:35 PM
Troy 85Z's Avatar
Car: 85 Z
What did you have to do? Just grind a little off the AC mount? Thanks
Old Feb 27, 2001 | 10:48 AM
gruveb's Avatar
Car: 1989 IROC-1
BlackZ,
What brand and part number did you use?
Old Feb 27, 2001 | 05:02 PM
BLACK Z's Avatar
Car: 86 Z28
I used the Edelbrock one for carbed cars., I just cut a pieace off of my ac braket, I did it so you can not even tell that it is missing ( unless you hold antoher up to it, It was simple.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
