"91-'92 Firehawk Wheels Rub on Tie-rod End
Old Feb 28, 2001 | 08:11 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I have a '92 Z28 and am trying to run the 17" X 9.5" Ronal Firehawk rims with 275 40ZR17 Bridgestone Potenza RE730/Nitto NT555R Drag radials. The problem is, the inside edge of the rim rubs on the tie-rod end. Is this a common problem, or do I need to grind off a small amount from my tie-rod end? I'm trying to avoid spacers if at all possible. I only need a few millimeters to get it to clear. How did the Firehawks avoid this?
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Mo steel for Mo stremph!
Old Feb 28, 2001 | 03:01 PM
kermit_one's Avatar
Hey Frank, The Z28 in CHP awhile back used TT II's 17X9.5's with the same size tires that your using.With a 5.5" backspacing it did mention grinding a small amount off the tierod ends.I'm not sure what your backspacing on those wheels are but it would have to be close to the 5.5. I'd say grind i minimal amount off and see if helps but don't get to carried away.weak tierod=badnews
92RS,POLO GREEN
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Fronzizzle
Mar 18, 2019 08:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
