Rad steamin
Old Mar 1, 2001 | 10:54 PM
ROCHEAD's Avatar
Rad steamin
Took the car off its stands after 2 and a half months of work. I installed a temp guage and a little fluid leaked out. Now i went for test ride down the street and back, and when i got back, the rad was steamin from the top a bit. Is this a saftey purpose or is my rad gone. The fluid was low, but not bad. So put more in, and its not comin out the top (yet) Im gonna let it sit over night and go back out to the shop to see if its leaked. Any info would be appr. Thanks
Old Mar 2, 2001 | 08:07 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
This isn't really the appropriate forum for this, but I had that problem a few years ago. I just replaced the radiator cap and the problem was solved. Apparently, the spring in the cap weakens over time and can't hold as much pressure. Because the boiling point of the coolant is lower at lower pressures, you get to the point where you're getting boil-over at slighty-above-normal temperatures or after you turn your car off.
Greg Westphal
'87 IROC 305TPI/A4
Old Mar 3, 2001 | 01:22 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Greg's right...get a new radiator cap. The same thing happened to me.
randy210
Oct 15, 2015 03:43 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
