weight jacks not designed for 10 bolt?!?!
Old Jun 4, 2010 | 10:01 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Soo here is my first piece of handy work. Drivers side there is a support underneath the spring perch thats in the way of the weight jack perch. Cut it out with a dremel because i didn't have enough room to get any other tool i owned in there.
So finally got enough cut out, go to drop the adjuster in and wtf, the perch doesn't drop all the way down. The welds as you can see on the bottom side are in the way. Racking my brain as to how i'm going to deal with this at the moment, not sure how much of the welds i want to grid off altho there shouldn't be much real force on that welded joint so it might be okay. I'm just not sure why just about no aftermarket parts ever bolt right in for me.
Old Jun 5, 2010 | 01:12 AM
87350IROC's Avatar
Car: 87' IROC
Re: weight jacks not designed for 10 bolt?!?!
I just checked my not yet installed weight jacks on my 9 bolt and I have the same problem as you. Except I will probably cut the adjuster instead of the panhard mount.
Old Jun 5, 2010 | 03:59 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ya i had thought about that, but you would have to cut off most of the locating section of the adjuster unless you remove at least a little. Be curious to know if you have any issue with the weld's not allowing the ring to sit flat.
Old Jun 5, 2010 | 06:29 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
You should pm or do a search for Stephen. He is the weight jack god from what i have seen. He loves those things to death.
Old Jun 5, 2010 | 08:47 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the adjuster just needs to sit there, if the welds are keeping oit from sitting totally flush, its no big deal. With the weight of the car, it will wedge itself in.
or maybe tack weld it a couple times to keep it from moving.
I have the front weight jack set, but never used the rear because i have to use coilovers, so i have never tried to install them.
Old Jun 5, 2010 | 09:49 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Old Jun 5, 2010 | 10:49 AM
87350IROC's Avatar
Car: 87' IROC
The welds get in the way a little bit but not as much as yours. I am not going to worry about. I don't think you should either.
Old Jun 5, 2010 | 12:06 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
good enough for me. I'll install them today. thanks for the opinions.
Old Jun 6, 2010 | 02:52 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
What i did on mine was cut just a portion of the adjuster just enough for it to sit flush like this. I cut basically a notch out of the bottom of the adjuster until it didn't hit the support brace. After I did that it sat in nice and flush.
Old Jun 6, 2010 | 06:02 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ya i'll take a better picture of what i cut out of the bracing, honestly i didnt remove enough that i think it'll make any difference structurally, altho it was a major pita.
The fact that it sits on the welds kind of annoys me, but i'm picky and it'll be fine for now. A few have gone coils in the back and weight jacks in the front, i think that really is the best setup.
Old Jun 11, 2010 | 12:52 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I ran into this issue when I installed my weight jacks. No one had mentioned this problem before I did mine. I ended up using an oxyacetylene torch to clearance the brace.
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
