Outer wheel bearing won't go on
Old Jun 10, 2010 | 04:00 PM
lonesomeloser's Avatar
Car: 1983 Z28
Took them off during the winter for my upgrading. Had them sandblasted and I repainted them. Starting to assemble everything but the outer wheel bearing won't slide over the spindle. The spindle shafts are clean, no debris. The wheel bearing will go maybe 1-2 mm onto the shaft then it fetches up. I even bought a new bearing and had the same result. Any ideas?
Old Jun 10, 2010 | 10:48 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Outer wheel bearing won't go on
1LE outer bearings are different and most common parts stores wont know the difference. I went through this mess the day before G14. Irritating to say the least
The PN you're wanting is A-34
Old Jun 11, 2010 | 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What did you have sandblasted and repainted?
The outer 1LE bearings have a different OD, but the ID is the same as the 34 to fit the OE spindle.
JamesC
Old Jun 11, 2010 | 07:29 AM
Car: 1983 Z28
That's good to know but I am using the same bearings that were on them before.
Old Jun 11, 2010 | 07:34 AM
Car: 1983 Z28
JamesC
I had the spindles sandblasted and painted. The drivers's side bearings went on as it should. It's the pass side outer that won't slide on. I am reusing the SAME bearings that were on it before, which only have 500 miles on them. Also the castle nut is needing alot of force the screw on, feeling like it's cross-threaded.
Old Jun 11, 2010 | 07:35 AM
JamesC's Avatar
So the inner slips on, but the outer won't?
JamesC
Old Jun 11, 2010 | 07:53 AM
Car: 1983 Z28
JamesC
Correct. In the back of my mind I thought the machinist gave me a different spindle, that's how tight the outer bearing is
Old Jun 11, 2010 | 08:00 AM
JamesC's Avatar
If everything fit before the spindle left your hands and now doesn't, even using the same parts, I'd have to wonder what transpired with the machinist.... And there's the question of the castle nut as well. If the threads on the spindle aren't galled, the old nut should screw onto the old spindle with little effort. Humm.
JamesC
Old Jun 11, 2010 | 12:18 PM
Car: 1983 Z28
Fixed! Took the spindle off and to the machinist. There was a tiny flat spot on the edge of the shaft underneath and a thread that had a burr.
Old Jun 11, 2010 | 02:24 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Get a bigger hammer..
Honestly, Everytime I go for wheel bearings at the store, they end up not fitting anyway..
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
dyeager535
Aug 28, 2015 08:10 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
