Front struts
Old Feb 28, 2001 | 02:29 AM
SNAKEHUNTER's Avatar
Front struts
I have a 1989 RS that I will be installing front struts. I know this has been posted before but I can't find it. What is the torque specs. for the bolts that hold the struts to the hubs? Thanks in advance.
Old Feb 28, 2001 | 03:54 AM
Omar's Avatar
203 Ibs.
1989 IROC-Z 5.7L
Old Feb 28, 2001 | 11:04 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
<font face="Verdana, Arial" size="2">Originally posted by Omar:
203 Ibs. </font>
Don't know where you got 203 lbs. at, but final torque is not supposed to EXCEED 148 lbs.
KAM
Old Feb 28, 2001 | 04:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually I could've sworn that 200 lb/ft was the spec for the strut-to-knuckle bolts.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 28, 2001 | 05:51 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I believe GM recommends 120 ft./lbs, but I'm not sure. I did mine at that much. Never had a problem. Keep in mind the rotation of the threads on top of the mount.
Old Mar 2, 2001 | 04:47 PM
Omar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by thunderstick:
KAM
</font>
I got 203Ibs from my 1989 GM shop manual. Where did you get yours?
1989 IROC-Z 5.7L
Old Mar 2, 2001 | 10:04 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
KAM
</font>
Different year manuals recommend different torques. Newer f-bodys had a lower torque specs for some reason. As long as its between 150-200, it should be fine. They're crimp nuts, so they wont fall off
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Mar 4, 2001 | 12:44 PM
Car: '91 Z28
Axle/Gears: 323's
I got 203Ibs from my 1989 GM shop manual. Where did you get yours?</font>
Chiltons... says 125 ft.lbs., followed by 120* turn, not to exceed 148 ft.lbs. (which apparently calculates to 200 Nm...), but you're talking ft.lbs., too, right? I dunno... 125-148 seems plenty tight... That's a heck of alot of diff between the 2 manuals though, ain't it?
KAM
Old Mar 4, 2001 | 03:38 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I used the 203 figure - actually probably more. (3" pipe x a lot of pressure = more than 203) I messed up the threads on the bolts so I got new 5/8 grade 8 bolts, washers, and nuts and used those. I think the knuckle bolt is some sort of metric thread that no hardware store near me carried so I used standard. If I have any problems I'll post (as usual)
"We lost Dale. This isn't fun anymore"
R.I.P. #3
"The inevitability of death serves as the most clear evidence that to truly live, one must constantly court death, flaunt death, smack death around, and basically grab death by the throat and dare it to come too soon."
- Me
Old Mar 5, 2001 | 07:43 AM
Car: '91 Z28
Axle/Gears: 323's
The bolts on mine were std. 15/16...
hmmmmm
KAM
Old Mar 5, 2001 | 09:24 PM
Metalifann's Avatar
Just use an impact gun and dont worry about it
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
redmaroz
Apr 25, 2017 07:14 AM
