question about my strut tower
Old Jun 5, 2010 | 11:31 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
so it seems that my strut tower (?) on the drivers side "slipped" towards the center and if now cutting into my air intake hose. will there be any problem if i just unbolt it a little bit, slide it back up, and tighten it?
Old Jun 5, 2010 | 11:56 PM
Stephen's Avatar
Car: 87 GTA
Re: question about my strut tower
That adjustment (those 3 studs) are part of your front end alignment. If you move one or both, you effect the alignment on the front end.
I would look more into seeing if you can turn the air filter housing away from it any (i know it sits in notches but...) then try getting the hose away from it to help some more.
I would NOT just randomly move the strut mount(s).
Old Jun 6, 2010 | 02:26 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I see no sign of slipage in the bolt/stud slots
Old Jun 6, 2010 | 06:21 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i dont see slippage either, the tower was put there on purpose. Either a crappy alignment job in a back yard somewhere, or something is bent from hitting a curb or something requiring the tower to be in that position for alignment purposes.
where is the other tower set? does the car drive straight?
Old Jun 6, 2010 | 08:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider slipping something between the two pieces for protection. The old L69 pass side duct was equipped with a piece of flexible plastic to protect it from rubbing.
JamesC
Old Jun 6, 2010 | 09:29 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Almost looks like the nuts are lose on the retainer. The tires will push the strut and plate up towards the engine if they are. . .
Old Jun 6, 2010 | 11:34 AM
Trah84Z's Avatar
Engine: 305 V8
here's the other side. i guess i figured it slipped because after all these years i never noticed it cutting into the hose. I haven't drove the car in a long time so i don't remember if it goes straight or not. i need to get new tires sometime this year, so hopefully an alignment will fix this.
Old Jun 6, 2010 | 01:15 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
stick a beer can between it.
Old Jun 6, 2010 | 11:15 PM
Trah84Z's Avatar
Engine: 305 V8
way to break the stereotype...i might as well use the lynyrd skynyrd tape that was in it when i bought it...
Old Jun 7, 2010 | 12:34 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its as good as your idea to just losen it up and move it around
that or just trim some off the end of the hose to make it shorter to get a fingers width of room.
unless your sure it moved but it doens't look like it.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
