Shock/strut help
Old Jun 11, 2010 | 05:18 AM
87TAGTA66's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Stock 3.23's
Shock/strut help
Ok so they are in serious need of replacement and I don't feel like taking it to a shop that's gonna charge me $450 to do it so thought I'd do it myself. Just by glancing at the job it doesn't seem too difficult so I was just wondering if anyone had any advice or if I'd run into any problems while doing it myself in the driveway. Also do I have shocks or struts? I have no idea how to tell the difference. It a stock 87 gta. Thanks for any help guys
Old Jun 11, 2010 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Shock/strut help
The job can be done in your driveway/garage with basic handtools, though air tools can be helpful, especially with the nut on the top of the struts; the rear has shocks.
Check the Suspension How-to sticky at the top of the page.
JamesC
Old Jun 11, 2010 | 08:05 AM
87TAGTA66's Avatar
Engine: 5.7 TPI
Sweet thanks man I'll check the thread out
Old Jun 11, 2010 | 08:20 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Fronts are..Struts
Rears are...Shocks
"No idea how to tell the difference"... Good luck on the install.
Old Jun 11, 2010 | 10:17 AM
RaisinHale's Avatar
Car: 85 IROC-Z
Engine: 355 SBC
Transmission: Powerglide
Axle/Gears: Moser 35 spline w/ 4.56 gears
Make sure you put plenty of penetrating lube on the top strut nut. I had a terrible time getting one of mine to come loose. I had to eventually use a torch to cut the nut off.
Good Luck with the install.
Old Jun 11, 2010 | 10:42 AM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Breaker bar and scraped knuckles got the top strut nut off, but if at all possible, GET AIR TOOLS and save yourself some skin and blood on the struts (front)
Old Jun 11, 2010 | 10:50 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
The hardest part will be having to take the rear interior panels off and pull up the carpet. I just did my rears yesterday evening. Took 30 minutes or so.
Old Jun 11, 2010 | 06:11 PM
JamesC's Avatar
No need to remove the panels. Check the above link for photos.
JamesC
1fastiroc-z
Mar 15, 2012 08:20 AM
Flightoficarus
Sep 4, 2010 11:28 PM
zigurat
Feb 15, 2008 12:36 AM
trans_am_ta_84
Apr 15, 2004 05:06 PM
bluegoose
Dec 11, 2003 01:45 PM
