brake problem
Old Mar 11, 2001 | 09:50 PM
v6-3.1's Avatar
brake problem
I have a 1990 camaro 3.1L V6. I have drum brakes in the rear. the rear right caliper was replced recently. I noticed that the brakes are mis aligning (when you press the brakes they dont go back to the correct position. how can I fix this problem. are the brakes adjusted too tight or too loose?
also are the calipers the same for all of the 82-92 f-bodies
Old Mar 12, 2001 | 09:16 PM
v6-3.1's Avatar
btt
Old Mar 13, 2001 | 06:27 AM
Belker's Avatar
Did you get a spring kit and change all the springs to new ones. The old ones may be wore out. It's pretty cheap and may solve your problem.
Old Mar 13, 2001 | 02:22 PM
v6-3.1's Avatar
the springs are new
Old Mar 13, 2001 | 09:22 PM
v6-3.1's Avatar
can anyone help me
Old Mar 13, 2001 | 09:35 PM
sslee's Avatar
If you are stepping on the brake with the drum off they will not go back. The brakes are moving out too far without a drum on it. Just push them back together and straighten them up, put the drum back on and adjust the starwheel until a very slight drag or scrape is felt when you turn the drum.
(((If this is not a new wheel cylinder and you have been pushing the brake with no drum on it they might start leaking!!!!!!!!)))))
Old Mar 14, 2001 | 02:45 PM
v6-3.1's Avatar
sorry for the mistake.
the right rear cylinder is NEW
Old Mar 14, 2001 | 03:28 PM
v6-3.1's Avatar
where is the starwheel??
Old Mar 14, 2001 | 03:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's on the adjusting screw inside the rear brake drums... looks like a star.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 19, 2001 | 10:17 PM
Dsaint's Avatar
The Bronx, I am also from the bronx. These streets are tough on our cars are theey not.
Old Mar 19, 2001 | 11:21 PM
v6-3.1's Avatar
Its flat out terrible out here.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
