sway bars
Old Mar 20, 2001 | 12:26 PM
a383z's Avatar
sway bars
I have been doing my research on sway bars and it seems that alot of people are buying the hotchkis aftermarket sway bars for like 150. But I noticed hellwiggs swaybars seem to be just as good and are cheaper and the hotchkis are 1 7/16 and Hellwig's are 1 5/16 to me not a big difference. And PST's bars are even smaller but only buy a fraction at 1 4/16 so to me it seems Hellwig's are a better buy. Can some one help me out a little before I buy this week.
Old Mar 21, 2001 | 12:05 AM
Tad's Avatar
Tad
I've Had Hellwig Front & Rear sway bars on my 87 camaro for about six years no complaints yet.
Old Mar 21, 2001 | 07:44 PM
82camaro's Avatar
Car: 82 camaro SC
I can't imagine wanting a stiffer bar than the hellwig bars. Solid 1 5/16 front and 1 inch rear are plenty big. To make your car handle good, you need a combination of parts. SFC's, springs, shocks/struts, etc...
The Hellwig bars are a good place to start. They are all poly bushings with one-piece endlinks. I've had them a long time as well without any problems.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 21, 2001 | 08:16 PM
a383z's Avatar
Whats the biggest size sway bars that were available stock.
Old Mar 21, 2001 | 08:38 PM
Belker's Avatar
I read somewhere that a very small difference in the diameter of a sway bar makes a very large difference in the stiffness of the swaybar. I forget the math that was given but I imagine that 1/16" makes a bigger difference than you would think.
What's the right size for your needs ... I don't know ... sorry.
Old Mar 21, 2001 | 08:53 PM
82camaro's Avatar
Car: 82 camaro SC
36mm hollow is the biggest stock bar for the front.
82camaro
Old Mar 21, 2001 | 09:47 PM
a383z's Avatar
Well thanks for all the help and after doing some more research. The reason everone uses the Hotchkis sway bars is they are the biggest you can possibly buy and the fact that they are hollow everything else is about 1 1/4 and the hotchkis comes out to about a little smaller than 1 1/2 which is kind of a major difference. The only thing else that come even close would be the 36mm holow that you guys mentioned which I could only imagine would be the 1LE sway bars which are probably near to impossible to find. So if anyone out ther has a 36mm hollow sway bar that they would like to unload you have a customer waiting. Other than that if someone else knows of the best deal I could get on a hotchkis one (Small side note the high performance corvette bars are about 30-32 and extreme high peformance are 38)
1992 383 Z-28 w/SuperRam intake and ACCEL DFI(waiting on AFR heads this winter)
Old Mar 22, 2001 | 01:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Actually the 36mm hollow "1LE" bar is relatively easy to find, it wasn't a 1LE specific item.
Old Mar 22, 2001 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have a used 36 mm front and 24 mm rear with brackets (the GM part number tag still in place, 14094344, on the 36. These were used on 1LEs, WS6s, and other applications. I BELIEVE they were the largest stock bars). I can provide the GM part numbers for the end links (poly or some synthetic, believe it or not) and insulators, if you wish. Should you be interested, please e-mail me.
JamesC
Old Mar 22, 2001 | 08:10 AM
82camaro's Avatar
Car: 82 camaro SC
Being hollow will reduce 'stiffness'.
82camaro
Old Mar 22, 2001 | 08:25 AM
JamesC's Avatar
As I understand it, the 34 solid is the stiffest, followed by the 36 hollow. It seems, if I recall correctly, that there is a weight difference of some 9 pounds or so. I'm speaking of stock applications.
JamesC
[This message has been edited by JamesC (edited March 22, 2001).]
Old Mar 22, 2001 | 04:34 PM
88TAGTA's Avatar
Has anyone used the Spohn sway bars? I think they're 36mm hollow front & 24mm rear.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
