cape coral fl ****ed up rear end
Old Jun 19, 2010 | 01:53 PM
thegoochking's Avatar
so last night i hit a slick comming arround a turn to fast lost control and do to bad brakes couldnt stop myself from hopping a median curb. My right rear rim is smashed up right tire is pushed about a foot inward toward the other tire, left tire now has about an inch between it and the fender well and the right tire from the back looks liike it is about a foot more foreward of the left tire. Im ****ed how much damage do you guys think i did and is it gonna be fixable. 1987 trans am gta 5.7l
Old Jun 19, 2010 | 03:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: cape coral fl ****ed up rear end
you seem to be exaggerating, no way for the wheels to move a foot in any direction without the car being ripped apart like a soda can.
you probably broke the panhard bar, or one of its mounting points, and maybe a rear control arm. Probably mashed a rim too, maybe bent the axle.
maybe jack up the car and look under it and see whats broken? post pics if you need help.
Old Jun 21, 2010 | 02:28 PM
got it to my friends shop. So far without putting it on the lift my rim is mashed which i knew already. But he said i snapped my cross member and basically everything on that side of the cars rear suspension is done. He also said he thinks i may have cracked the frame im hoping not. Ill find out more when he calls me after it goes on the lift.
Old Jun 21, 2010 | 02:32 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
There is no rear crossmember.
Old Jun 21, 2010 | 02:34 PM
well where is the crossmeber because he said mine was snapped
Old Jun 21, 2010 | 02:59 PM
built91Z28's Avatar
The crossmember is up front and is what supports the motor. If all the damage was out back then he must have been talking about something else. As 86TA said, its probably the panhard rod.
Old Jun 21, 2010 | 03:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the upper panhard support bar is a crossmember of sorts. It does sounds like the tore the passengerside panhard mount off the frame. Not going to be a fun fix.
i want pics of the carnage!
Old Jun 21, 2010 | 03:59 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
That's all I can imagine the guy talking about. On the upside, depending on the actual damage to the metal, the fix may be pretty easy and quick if you have some welding skills and access to such equipment.
Old Jun 23, 2010 | 11:35 AM
im going by today it should still be on the lift i will take pics. But he said that i messed up the unibody as well with the impact cause i didnt hit the median str8 the back tire hit it at an angle. Told me that it would cost way more than the car is worth to do a full repair. Not fun to hear and its a friend of mine so hes not trying to ripp me off. Gonna talk to him today to find out my options
Old Jun 23, 2010 | 06:33 PM
car was off the lift but the verdict was the panhard did snap in half and he prety much rewelded most of the carnage but he said the rear end of my unibody on the passenger side is pushed foreward quite a bit and the entire rear end of my car needs to be replaced.
Old Jun 23, 2010 | 06:37 PM
my gold ws6 rim is also completely caved in so now i have to find a dam replacement.
Old Jun 23, 2010 | 08:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
still waiting for pics
Old Jun 23, 2010 | 08:17 PM
will not be able to get pics for a litte bit since that was my only car.
Old Jul 7, 2010 | 11:42 AM
"so yea i now need a new rear end. He says it has to come off of a gta from my year due to the ws6 suspension on the car. Is this true?"
Old Jul 7, 2010 | 11:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No.
JamesC
Old Jul 7, 2010 | 12:05 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
ws6 isn't different in mounting locations of suspension pieces, so any rear end will work that comes from a third gen. you can use a 4th gen rear too, but the tires will stick out 2 inches on each side because it's wider. just match drum brakes to drum brakes or discs to discs and you should be set.
Old Jul 7, 2010 | 12:14 PM
ok guys thanks that should make the search much easier, its driving me crazy not being able to drive her.
Old Jul 7, 2010 | 12:54 PM
JamesC's Avatar
Use your current springs and sway bar (if it survived) on the new rear and your WS6 will be in good order. I don't know if you have a 9- or 10-bolt, but the following link, where combination valves, speedo correction, and brakes are concerned, might be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 7, 2010 | 01:44 PM
87WS6's Avatar
This is not true. There are some differences between some year models such as the PBR vs. non-PBR rear brakes, etc. PBR's came on 1990 and newer cars if I recall correctly. Or was it 1989? In any case those may require a change in your E-Brake cable setup as the brake calipers are completely different. This is also true if you switch to a 4th generation rear end as they'll be PBR brakes, but they'll be different still. The other differences are 9-bolt vs. 10-bolt, 26 vs. 28 spline axels, positraction-vs. non-positraction. That's about it.
More or less. Of course you'll want an adjustable panhard rod in order to use a 4th generation rear as that will allow you to center the rear end under the car. Without that the rear end may stick out on one side and not the other, not just a little on both sides. At least that is my present understanding of the situation. Again the E-brake setup is very different so bear that in mind. Some fabrication is involved in making the E-brake work. In most states you'll need that to pass safety inspection.
Old Jul 7, 2010 | 02:07 PM
JamesC's Avatar
Originally Posted by 87WS6
Or was it 1989?
89 was the first year for PBR's.
No fabrication is required for the parking brake cables, even the LS1's (check the link I provide above).
JamesC
Old Jul 7, 2010 | 02:12 PM
87WS6's Avatar
JamesC
I've been under both of them. The LS1 E-brake cables are mounted very differently than those in the third gens.
Old Jul 7, 2010 | 02:16 PM
JamesC's Avatar
Here's what I was speaking of:
http://www.flynbye.com/catalog/i153.html
JamesC
Old Jul 7, 2010 | 02:25 PM
87WS6's Avatar
JamesC
Ahh. I didn't know those existed. Well that makes things easier.
Old Jul 7, 2010 | 05:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i have them, and they work great too
Old Jul 11, 2010 | 11:31 AM
hes taking a 3.42 10 bolt posi rear from a formula same year as my car that had a 383 in it. Not sure all of what hes gonna do but hes got quite a bit of built camaros and birds from 69 and up so im sure he will get her right. To bad the car didnt have a spoiler since im still looking for one.
Old Jul 12, 2010 | 06:03 PM
she is fixed but now i am rolling on a little doughnut in the front till i can find rims cheap im taped out of money. Anyone localy have a gold gta rim or a set of rims they are willing to sell cheap? im in south west florida ft myers cape coral area
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
