Bad problem with front drivers side tire :(
Old Apr 2, 2001 | 08:58 PM
Stell1579's Avatar
ok guys, here is what happened
i was cut off in the rain, jam brakes frocing me to skid, hit a curb with about 20MPH and the car jumps up on to it. the rim broke (missing a chunk) and the tire blew out....got new rims and 2 new tires. the stering wheel ists croked and the car kinda pulls slightly when breaking....
i took the car to sears to have front end alighnment...he said every tie rod/baljoint is in great shape BUT he wont alighn the car because it seems the driver side front tire is pushed back about an inch.. i noticed one bolt between the back of the front tire and the frame (on the door side of the tire) it goes strait up into the subframe it looks liek th ebolt walked (or when the bolt holds had moved about a 1/2 inch) now i think that could be my problem....what else could it be??? bent the a-arm?(front LCA)
all ideas welcomed....
thanks
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, SLP AirFoil,180 Thermostat+ Temp Switch, Relocated MAT, Cold Air, Hooker Aerochamber Catback,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
http://stell15790.tripod.com/cars.htm
Old Apr 2, 2001 | 09:19 PM
82camaro's Avatar
Car: 82 camaro SC
I could guess it's the control arm or control arm mount or subframe. But the only way to find out what the problem is, is by taking it to a reputable body shop that has a frame machine. Or, you could just replace the control arm and strut(could have some internal damage) and see if that fixes it. Control arms are cheap from a junkyard.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
db057
Aug 22, 2015 08:17 PM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
