Baer Brakes
Baer Brakes
I just installed Baer's 12" Sport System with 16" IROC wheels. I took some pics of the inside clearance. Anyone have any pics with the 13" rotor? This one comes close.. Sorry if they are blurry or big..new camera.
http://home.san.rr.com/iroc/Exterior/rims2.jpg
http://home.san.rr.com/iroc/Baer/f-baer.JPG
http://home.san.rr.com/iroc/Baer/f-inside1.JPG
http://home.san.rr.com/iroc/Baer/f-inside2.JPG
http://home.san.rr.com/iroc/Baer/f-inside3.JPG
http://home.san.rr.com/iroc/Baer/f-inside4.JPG
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
Looks great Omar. If you went with the 13" rotors you would add about 1/2" do the diameter you have now. It's hard to tell, but you probably don't have quite that much room left. I had heard that the fins on the caliper could be ground off a little to make them work. But for the amount of money invested in the system, I wasn't going to take a chance on having a problem. You won't be disappointed in the performance at all. The 13" system uses the same calipers and pads as what you have now. The only advantage you would get is a small one with more leverage on the larger diameter rotor. The Baer rep I talked to said preformance is almost the same. I would bet that under road racing conditions you could tell a difference, but other than that very little. Good luck, take your time braking them in... it'll be worth it. Rob.
Thanks, Rob. And thanks for answering my questions prior to installation.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 150HP kit
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Omar,
I fitted 13 1/2" to my trans am and the standard 16"rims wouldnt fit,so i fitted 18"s
Lovely jubbly.
Baer brakes work superb.ive now got 6 pot Alcon calipers to fit
cheers
powermite
Lovely jubbly.
cheers
powermite
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have 15" Z28 wheels on my 1LE equipped 82Z28. I do not have any clearance problems.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Tadder, I just happen to have Bell Tech's drop spindles on my car. That is what you are seeing in the pics. The only bad part about that is that they charge you for new spindles, and they DO NOT accept your old spindles back for a core. So you are either stuck with them, or selling them on ebay or something.
1989 IROC-Z 5.7L
NOS 150HP kit
1989 IROC-Z 5.7L
NOS 150HP kit
So you are saying you got the kit with spindles you did not need right? Getting rid of the spindles should not be too bad. Did this kit bolt right onto the dropped spindles? Please tell me they did. I would like to know the number for your front kit. The brakes look great. Other companies told me that I would have to send them the spindles and they would have to modify. Who to believe?
Car: 91 RS
Engine: 5.0
Omar, How long untill you get everything on the car, I cant wait to see the finished product.
91 RS Conv. 305 tbi no cat. 16" IROC rims, whiteface guages. More soon.
What Baer does is send you a Bell Tech spindle completely built up already. It has the rotor, anchor plate, caliper, and pads built onto them. You take your old spindles off, and just bolt on this new unit. Your old spindles are now paperweights, or an ebay auction.
Baer has different names for their systems. Their most popular being the 12" Sport System and the 13" Track system. When you order, you just tell them to build whatever system you order onto Bell Tech spindles.
I got a little ansy with my sig, but I get my new Probuilt 700R4 this monday or tuesday. After that, I will give it a wash and take some pics of the finished product.
1989 IROC-Z 5.7L
NOS 150HP kit
1989 IROC-Z 5.7L
NOS 150HP kit
Thanks for all of the info on this subject. You have solved my problem. A call to Baer brakes is the answer. I will call them this summer and just tell them what I need. Look forward to seeing the brakes on the car.
As soon as i get the money i think i'll get the 12" package zink washed with slotted rotors. They look awesome and perform even better. Ive heard they are also lighter than the stock brakes, is this true?
'91 Z28 - 50,000 miles. All power options leather. 350 TPI:
K&N; Fastchip; Airfoil; Custom 'Ram-Air'; SLP Headers; Slp Runners; Borla Catback 50% open; Dual factory Cats; Poweraid TB spacer; March underdrive pulleys; Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs; manual fan switch; TB coolant bypass; Pirelli P7000 Z245/50/R16 all season tires; Energy suspention motor mounts; smog pump delete.
S Cobra Radar Detector; Z28 SS Floormats
dbrochard
Sep 19, 2015 08:13 PM
84 TA NV
Sep 6, 2015 08:02 PM
