Removing Control Arm Bushings...Burn 'em or Press 'em?
Old Apr 6, 2001 | 08:06 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
what did YOU do when you rebuilt your front end (or have the shop do?)
did you blow them out with a torch or did you have them pressed out?
I've heard that pressing them is hard on the control arm, but I'm skeptical.
Clem
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, (unfortunately) auto, NO T-tops---FOR SALE---
Looking for a V8, 4 or 5 speed Camaro with NO T-tops (wanna trade?)
Old Apr 6, 2001 | 09:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Air chisel
ICON Motorsports
Old Apr 6, 2001 | 09:34 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
HEY!
I've got one of those. what's the preferred method there (how do you knock out)? do you hammer away at the rubber until it's gone? do you have to worry about tearing up the control arm? I might give it a whirl tonight with the arm I just pulled off of a wrecked IROC.
thanks
Clem
[This message has been edited by clemsparks (edited April 06, 2001).]
Old Apr 7, 2001 | 05:13 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
You could use the air chisel, but if you slip enough you'll end up chopping the control arm. It's really not that hard to let the blade slip! It only costs a couple of bucks at a machine shop to have them do it, and IMO safer as well.
Old Apr 7, 2001 | 10:38 PM
Jason M 91Z's Avatar
If you take the control arm to a machine shop, they're gonna use an air chisel to get them out. The big short bushing is easy w/ the chisel, but the long one is knurled at the end. I just take a blunt tip and wrinkle it in then go at it w/ the chisel. When you press the new ones in, make sure you use spacers in between the control arm holes so you don't collapes it.
-Jason M. 1991 Camaro Z28
Old Apr 7, 2001 | 10:52 PM
92TRANSAMWS6's Avatar
I used a balljoint installation tool to remove and install my bushings...took about 20 minutes total.
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
