Low vacuum cam gets me poor brakes, help
Old Mar 29, 2001 | 11:57 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Last August, I installed the TPIS ZZ9 cam. I think that this cam, having more duration and/or overlap, creates low manifold vacuum.
The car barely stops at all. Last month, I even installed the 1LE upgrade kit from SSBrakes. Still, the car barely stops. I bled the brake fluid properly and have a firm brake pedal.
What can I do about this? I got to get better brakes!!!! If not, I may get into a bad accident.
I have heard of vacuum canisters or assist vacuum motors. What should I do?
Please help.
TIA
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Mar 29, 2001 | 12:31 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
How much vacuum are you pulling with the ZZ9? IIRC, anything over 14 inches at idle is acceptable to operate the brakes effectively. A lot of ZZ9 users seem to use their brakes fine without using a canister. Perhaps you have a small vacuum leak elsewhere when you reassembled the top end...
BTW, do you have a website for the SSbrakes?
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
[This message has been edited by IROCZZ3 (edited March 29, 2001).]
Old Mar 29, 2001 | 01:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the vacuum check valve in the vacuum hose to the brake booster.
SSbrakes is http://www.stainlesssteelbrakes.com
Old Mar 29, 2001 | 03:40 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Apeiron,
Can you explain the check valve, how does it work and what is its function?
The vacuum leak may make sense since the engine idle is surging a little bit.
I will check the vacuum check valve and for a vacuum leak somewhere in the intake system.
Old Mar 30, 2001 | 10:26 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I can hear a vacuum leak back near the distributor. However, the lines back there are OK. Lit a cigareet and the smoke moved under the plenum. Apparently, I have a vacuum leak near the EGR which I cant see at all. Now I get to remove the PITA SuperRam.
Old Mar 30, 2001 | 12:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I guess you could try adding an additional vacuum tank; the one on your car is on the firewall, looks like a plastic rectangle. Or wait, do '91's have that big plastic bubble as the vacuum tank?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 7, 2001 | 07:38 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
Buick GN's use an electric braking system - they cost a fortune though - probibly not the way to go but im just adding another option
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Old Apr 7, 2001 | 11:10 PM
82z's Avatar
82z
The vacuum check valve keeps a vacuumm in the line to the brake booster so you still have power assist under low manifold vacuum conditions. All you have to do is see if it holds vacuum. Kane I thought GNs used a power steering assisted system?
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
cstrobel65
Aug 15, 2015 10:19 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
