Anyone use MOOG springs?
Car: GTA
How do they look height wise? I don't want my GTA to look like a ******* thirdgen monster truck. What is the spring rates on them? If you have the part #, that would be a plus. Thanks
88 GTA L98 SSM frame connectors Hotchkis STB ADS Offroad chip Transgo shiftkit All free mods
85 T/A LG4 WS6 Stock
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I replaced mine last year, front and rear, with MOOG's, and the car sits at "stock" height. I don't have the part # handy, but can get it for you later on...
KAM
KAM
i have them in the back...havent done the front yet. but anyway the rear ones are heavy duty (the heavy duty pn. starts with CC) and they are just fine...no redneckin
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Car: 4
Engine: 6
Transmission: 5
I have them; I got mine from NAPA (reboxed Moog), I looked them up for IIRC a 87 IROC with optional suspension. They end up being the shortest, highest rate ones with the right shape ends, right outer diameter, and right wire diameter. You can easily pick them right out of the buyer's guide section if you take the time to study all the specs.
The only spring Moog lists for the rear os these cars is the CC number referred to above, which stands for "Cargo Coil". That's Moog's trade name for variable-rate springs. I have those too. My car sits a little higher in the front than I would like; but it has a fiberglass hood, aluminum water pump, mini-starter, aluminum radiator and 5-speed; so it's just light on the nose, period. It's about level instead of having slight (½" - ¾") forward rake.
ICON Motorsports
ICON Motorsports
Car: 2002 SOM z28
I got the fronts from MOOG too, and I cannot say for sure I got the CC version, but mine are rated at 700lb/in rate. Like RB, I have a lot of things that are way lighter then stock and my front sticks up a little too high for my taste. I may yank them out and chop off 1/2- 1 full coil to lower it a bit. I have no fears of grounding out with these springs either!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Car: '91 Z28
Axle/Gears: 323's
Hey - sorry about leaving you hanging... I forgot all about this stuff. The MOOG p/n's I have are FRONT: MOO5662; REAR: CC635
Hope that helps you out. Once again, sorry - it's turned into one of those days...
KAM
KAM
I'm running Moog 5662 also, had to remove 1/2 or 3/4 coil to get the height down to where I wanted it. As delivered they were very close to factory ride height, I wanted something between that and Eibach's Pro Kit which was just a tad too low.
I buy mine at a local shop. Watch out for Wrenchead.com as they are confused about pricing...it's ~$70 per pair but they consider them individually, so you end up paying 2x what you should.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
-Kevin
1982 Z-28
Want to hear crazy! I am running the Moog 5664's (707 lb-in) up front (a little high but stock) and 86 CHEVY CELEBRITY SPRING OUT BACK! The rear springs are supposed to be a tangential end on top but in reality the rubber isolator makes a flat or square end spring work fine, as long as the spring is not ground flat just bent flat. I used Celebrity springs to get 160 lb-in springs that matched the stock ride height of the Moog 5664's and fit our rear axle. Gulstrand Engineering recommends this spring rate in my HOT ROD Camaro book of magazine articles and I have had good luck with them. NO problems at the strip or anything. Pretty cool what you can find in a spring book.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Recently Ported Heads, Installed Larger Race-Flo Valves and RPM Air Gap Intake (No new times)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
[This message has been edited by CamaroMike (edited April 07, 2001).]
The Bowtie
Wow, that's great info on the rear springs. Did your Celebrity springs have the little letter-code tags still attached...and what are they?
I was in the junkyard today shopping for a low, soft set of rears for the road course and saw a bunch of non-f-body rears that would have fit. Any help on what letter-code(s) to shop for is greatly appreciated.
On your Moog 5664s, the Moog book shows them to be 760lb/in rate...super stiff.
1982 Z-28
1982 Z-28
I just bought GlobalWest S-9 street springs. They're 640lb linear springs. The car will hopefully be on the road in a few weeks so I'll let you know how I like them. They're supposed to drop it about an inch, and next to my stock BZW front springs, they're about 3/4" shorter.
-Jason M. 1991 Camaro Z28
Car: 92 Formula
Transmission: A4
Which MOOG springs would you get if you didnt want an incredibly stiff, but fairly stiff ride.
Basically, I want my car to feel (suspension wise) kinda like the new camaros. It handles really good, but doesnt sacrifice comfort (bouncing hard over every bump....)
So what would you go with?
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
92 Rs 3.1/T-5
AIM : Theonekiztope
ICQ: 8787542
Kevinc, the spring number on the rears are Moog 5659. The front springs are stiff but not too stiff. Hell, they are stock convertible IROC springs.
The Bowtie
The Bowtie
LT1Formula
Oct 8, 2015 08:34 PM
