Will this fit uder my front feders with out rubbing
Old Apr 9, 2001 | 11:05 PM
GOLD85's Avatar
will 235 60r 15 BFG radial T/As fit on stock Z28 rims with out rubbing the iner fender wells when i turn wheels lock to lock, also will 12.5x28x15 M/T et street slicks fit
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
[This message has been edited by GOLD85 (edited April 09, 2001).]
Old Apr 10, 2001 | 10:21 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
I have 15x7 rims on my 84 Z28 with 235/60/15. I have never had them rub. Can't help you on the slicks.
Later,
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 at 94.77mph
Recent additions: Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts. Need relocation brackets and control arms.
Jeremys87
Jul 14, 2022 09:08 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
