Spohn LCA Relocation Brackets
Old Mar 27, 2001 | 12:21 PM
FlashGTA
Guest
Posts: n/a
Has anyone tried the Spohn LCA Relocation Brackets? Did they help? Thanks!
Old Mar 27, 2001 | 12:56 PM
Mark 89Formula's Avatar
I have them and they work great. Traction with drag radials is good enough to run sub 2.0 60' times with a fried posi. One of the best bang for the $$ out there.
Old Mar 28, 2001 | 01:57 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I ran a 1.88 60" with no suspension mods...
I will kind of let you know what they do by the 16th of April.
I am getting the floor pans and transmission tunnel fixed and adding these components of Steve's on to my car:
LCA
LCA relocation brackets
Torque Arm
Panhard Rod
Sub-Frames...
I know I can't tell you what they do just for the LCA brackets.. But I will keep everyone updated on what the total package does.
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
Old Mar 28, 2001 | 04:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've got the same package on order as Raven, going to be playing with the welder over Easter.
Old Mar 31, 2001 | 05:00 PM
FlashGTA
Guest
Posts: n/a
Well, reading the replies no one has told me anything to convince me they work.
Old Mar 31, 2001 | 05:37 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
Re-read the first reply the you got; the one from Mark 89Formula.
Old Apr 1, 2001 | 01:18 AM
FlashGTA
Guest
Posts: n/a
I read the first reply, but he didn't give me a 60 foot number before installing the relocators so it's to subjective to me. I understand they work great, but I'd like to hear his 60 foot time before and after.
[This message has been edited by FlashGTA (edited April 01, 2001).]
Old Apr 1, 2001 | 12:18 PM
Before: 2.04-2.15 secs
After: 1.89-1.98 secs
All passes on Nitto drag radials driving through one wheel.
Old Apr 2, 2001 | 02:19 AM
FlashGTA
Guest
Posts: n/a
Thanks Mark, that's what I was looking for!
Old Apr 18, 2001 | 10:42 PM
craiger's Avatar
I have Steve's Lca's and panhard rod on my Z28. My best 60 foot time before the mods were 1.92 60ft time. I was debating on going to the relocation brackes and or using the nitto 555'r's? I am running the BFG comp TA's and when i jump on the gas and it drops from second to first i spin until i let off the throttle. I just wanna hook up and ever after the lca's and panhard rod, i still just spin? Please HELP me Hook up!
Old Apr 19, 2001 | 01:23 PM
82camaro's Avatar
Car: 82 camaro SC
If you look closely at the rear suspension, it's fairly easy to see why the lca relocation brackets work. They use the forward force from the axle upon acceleration to force the tires into the pavement. Without the brackets, especially on a lowered car, the opposite happens--the tires are actually pushed away from the pavement. They work. They also, IMO, help handling by increasing forward bite as you come out of the corner.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 19, 2001 | 07:19 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
82 Camaro:
You've said that relocaion brackets help increase traction on the way out of a corner.
OK, so what about going into a corner. Do you know if they have any negative effect on lateral grip as you go round the corner before nailing it on the way out.
Also, what about straight line braking. I expect there's no differance there as the rears don't do much braking anyway.
Thanx
Old Apr 20, 2001 | 11:50 AM
82camaro's Avatar
Car: 82 camaro SC
Haven't noticed any negative affects going into the corner. Or braking. It just puts the suspension geometry where it should be.
82camaro
Old Apr 20, 2001 | 12:34 PM
craiger's Avatar
So do you think that i should spend my cash on lca relocation brackets or drag radials? I will eventually do both.
6speedIROC
16
Mar 15, 2023 08:33 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
