Replacement brake line for a '89 GTA
Old Apr 17, 2001 | 05:19 AM
Paul Seymour's Avatar
Help, please.
I would like to know where to get brake tube for the above car. I am converting to right hand drive and need to re route the brake lines with new tubing, also need info on flareing tools and fittings. From what I can tell the line is 6mm and the fittings are M12X1, sorry about the metric but that is the best fit as it doesn't measure up the other way.
Cheers, Paul.
Old Apr 21, 2001 | 10:33 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Well man you are in quite a prediciment. I just had a line bent for my frind. It cost $17 at a shop to do it. If you can do it yourself I would go to a place like Harbor Freight and get some cheap tools to do the job. If you have the nuts on the ends from the old ones I think you will be ok. I would reuse them. Do you have the old line? If so I would just look for a shop that can rebend one for you. If not I would find a place that sells the tools and do it yourself.
James
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Apr 22, 2001 | 08:22 AM
ede's Avatar
ede
as far as i know all third gens use what is called an iso or european flare and use a differant nut than on the more common flare used on cars. the lines are 3/16", i think, but that may be americanized of a metric size. like was said before if you have the nuts the tube and flares should be easy to find and make. even if the tube is a little bit off in size it should still work.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
