Pulls To One Side During Hard Stops
Old Apr 14, 2001 | 09:24 PM
F-B0DYCAMAR0_83's Avatar
I got a 83 Camaro and it pulls hard to the left under hard braking causing the left wheel to lock and the right kicks in after a second or two. I have replaced the calipers, rotors, and pads, also adjust the rear brakes. Any ideas?
Old Apr 14, 2001 | 10:03 PM
NavyVette's Avatar
One of your rubber brake lines is collapsing and causing the fluid to get to that wheel slower. The inside of the brake lines will collapse over time. Replace the rubber lines going to your calipers and that should fix your problem.
Jeff
Old Apr 15, 2001 | 05:36 AM
kermit_one's Avatar
what he said....lol
you can also get the braided steel lines from earl or russel wich are a little better.
92RS,POLO GREEN
Old Apr 15, 2001 | 05:41 AM
Old Apr 16, 2001 | 02:49 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
From your description (kicks left, then kicks right), I'd say your right hose is the one that's shot. BUT- replace them both at the same time; it's safer that way.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 18, 2001 | 01:26 PM
JoeIROC's Avatar
i had the same problem a few months back. Try bleeding the brake lines, If one bleeds slower than the other (or not at all) then you know the problem is in the hose.
Replace both hoses at the same time. it's not too hard, but you will need to bleed the brakes afterwards.
BTW, after i replaced the hoses the car stopped smoothly. I can almost guarantee that the one hose is bad on your car.
86 IROC TPI 305
700-R4
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Next mod = trans-go shift kit (level 1)
Old Apr 22, 2001 | 09:47 PM
Belker's Avatar
I had the pulls-when-braking problem until I replaced both front brake lines about 3 days ago. Problem gone. Total cost $24.00 and about 2 hours labor.
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
