I want my car to ride on rails
Old Apr 22, 2001 | 11:57 PM
matthew's Avatar
I want my suspension to be very tight. I just put on new shocks/struts and it has made a tremendous difference. But while I was under the car I noticed that my sway bar bushings were practically falling apart! So I know that my sway bar isn't doing much. But I have big plans for my car this summer. They include new polygraphite bushings all around. 17" wheels. I'm thinking about lowering it 1-1.5". And getting some SFC's and a STB. I'm sure that after this is all done my car will ride about a 1000% better. I was wondering if theres anything else I should do to tighten up my suspension. Would new LCA's help, or are they mostly for drag racing. I also might get a new panhard bar. I'm not going to auto-x my car, but I do want to be able to take 25 mph corners at 50 Any comments/suggestions please feel free to talk.
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Apr 23, 2001 | 07:31 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Aftermarket lower trailing arms and panhard rod with poly bushings, poly bushings for the sway bar mounts and end links, poly tranny and torque arm bushings, sub-frame connectors, new steering parts up front (inner/outer tie rod ends, center link, and idler arm), and maybe even poly front lower control arm bushings and new ball joints will make a world of a difference in how your car handles. Trust me, I've done all of this (except I have the Global West lower trailing arms with the spherical bearings on one side) and my IROC handles -very- well. With 245/45R16 g-Force T/A R1's, it went exactly where I pointed it and I couldn't get the tires to slide regardless of how hard I pushed the car through turns, both on a road-race course and an auto-x course.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 23, 2001 | 10:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider a 1LE/WS6 type sway combo, or an aftermarket version.
JamesC
Old Apr 23, 2001 | 10:19 PM
82camaro's Avatar
Car: 82 camaro SC
Just like to add, aftermarket drop springs and big sway bars.
ALIGNMENT
ALIGNMENT
ALIGNMENT
-.5 camber
+5 caster
-1/16 to -1/8 toe
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Linson
Aug 21, 2015 02:12 PM
djmarch
Aug 9, 2015 05:27 PM
