brake conversion
Old Apr 14, 2001 | 12:55 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
brake conversion
what year did 4 wheel disc brakes come out in z28 ,,, i am looking to aquire an 82 in australia... its got 1960,s type drum brakes on the rear ,,, can i do a simple conversion, or do i need a rear end, and a master cylinder & booster ,+ associated hardware ,,, steve in australia
Old Apr 14, 2001 | 04:26 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Steve, I would try to find a donor car. Then simply swap in an '89-'92 complete disc brake rear end assy. Parking brake cables, etc.
If you can do it? We would love to see a picture of your car. Right hand drive??
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Apr 17, 2001 | 11:41 PM
FORD Rustangs -R- Us's Avatar
did any year get front and back disks?
just outa curiousity because ive never used them, will the standard brake setup on a 1992 camaro RS v6 5 spd stop the same or better then (just for comparison sake since its my ride for another 2 weeks) a 1998 blazer LT with ABS? what kinda of brakes did the camaro get? front disks..rear drums?
Old Apr 17, 2001 | 11:57 PM
Mo's Avatar
Mo
some had front disk rear drum
others front and rear disks
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Apr 18, 2001 | 05:37 AM
ANDYZ28's Avatar
Car: 1982 Z-28
If someone can help me out? I have some really nice pictures of his '82 T/A. It is in very nice condition. How do I post them??
Old Apr 18, 2001 | 11:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can post those for you Andy.
Old Apr 19, 2001 | 05:35 AM
ANDYZ28's Avatar
Car: 1982 Z-28
I just forwarded it to you. I still can't believe it's an '82. It looks to be in near new condition.
Old Apr 19, 2001 | 12:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
[This message has been edited by Apeiron (edited April 19, 2001).]
Old Apr 25, 2001 | 05:40 AM
Dan W's Avatar
When I did my 9" swap I went with a set of aftermarket units from a company called TSM. The kit uses an 11" rotor. I'm pretty sure they make a kit for drum braked thirdgen rears. They will sell just the brackets if you want or a whole kit. Calipers with emergency brake provisions are available. Total cost for the kit I have was less than $300.
TSM, 9635 Hwy. 85, #8, Littleton, CO 80125, 303/688-6882
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Old Apr 25, 2001 | 08:51 AM
82 T-TOP's Avatar
Thanks Andy for posting my pics. If I had known I would have put the bowling bowl wheel caps on and washed the car. ( can see dirt on the back bumper )Next time. Not a bad ride even after 100,000 Miles. Goes like a rocket. Could not notice much change going from a 3.23 to 2.73 rear end swap just finished. With donor cars in Australia. As far as f-body's go, unless a ralation who has one dies and leaves it to you, forget it. Getting some parts here is a nightmare sometimes or very expensive. Lucky mine in 10 yrs has cost me less than if I had a local made car and maybe held it's resale value better. The price you pay for a quality ride.
Steve, If you look at the pics on the post by Andy in this forum. I have a '94 disc rear now with posi (due to my old posi dying, which had drums)It cost me A$600 in Melb. and no extras needed. Have not changed M/C or Valve. Had to make small mod'f to h/brake cables which came with rear. Wheels now 50mm further out each side. No problem with 225-60-15 tyres ( tires ) for you Americans. If you need help in Aussi, feel free to fax me.
LittleFranks
Oct 7, 2015 11:26 PM
dbrochard
Sep 19, 2015 08:13 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
