Do all 3rd gen disc brake rears come with posi?
Old Apr 25, 2001 | 03:20 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I'm looking to replace the old drum brake rear in my 88 camaro with a disc brake rear end from an 86 T/A Firehawk. It's in the local junkyard. I want to know if it has posi or not. This car does not have the RPO's cause it's been gutted. Any help is appreciated. Thanks, Paul M
Old Apr 25, 2001 | 05:07 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Not "all" third gen disc rears were posi.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Apr 25, 2001 | 06:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Andy's right.
JamesC
Old Apr 25, 2001 | 09:32 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
86 T/A Firehawk?????
Old Apr 25, 2001 | 10:13 PM
BadBowTie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by paulmoore:
I'm looking to replace the old drum brake rear in my 88 camaro with a disc brake rear end from an 86 T/A Firehawk. It's in the local junkyard. I want to know if it has posi or not. This car does not have the RPO's cause it's been gutted. Any help is appreciated. Thanks, Paul M</font>
If you can physicaly lay your hands on the rear, simply give one of the rotors a twist. If the other rotor rotates in the same direction it's a posi, if it moves in the opposite direction it's an open dif. No need for RPO codes on this one.
'86 Camaro SC 2.8 V6, 5spd, T-Tops
Bone Stock, except for:
(Performance)
Flowmaster cat back exhaust
(Non-Performance)
Pioneer DEH-P4000 head unit
Pioneer 6X9 Tri-Ax speakers
Jensen 8" dual voice coil sub
Blacked out tail lights and side markers (VHT
Nightshades spray tint)
(Hopefully these lists will grow quickly)
I like to think of it as a empty canvas
Old Apr 26, 2001 | 08:56 AM
Jza's Avatar
Jza
Unless the clutches are roasted...
Old Apr 26, 2001 | 03:23 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
What is an 86 T/A Firehawk?
btw my 84 Z28 has a disk rear but no posi
Old Apr 26, 2001 | 05:31 PM
paulmoore's Avatar
I believe that the Firehawk is a limited production edition. It has the rear disc brakes with the 5.0L HO V8. It also has the WS6 package with a 30mm(I think) front swaybar and the thick one in the rear. It also came with the P245/55/R15 tires.
Old Apr 26, 2001 | 05:37 PM
paulmoore's Avatar
Actually, the front swaybars are way bigger than 30mm. Don't know the exact spec though.
Old Apr 27, 2001 | 09:50 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
First Firehawk was 91-92. Someone is full of ****.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
