Corvette suspension
Old Apr 26, 2001 | 10:31 PM
MasterGo8's Avatar
Corvette suspension
I have the ability to get the front suspension off of a 96 Corvette. Would this really improve my handling that much and also eliminate my strut towers? How hard of a job would this be? I really want my car to handle well and I am willing to do anyhting to do this. Thanks, by the way, I have an 85 Z28.
Old Apr 26, 2001 | 10:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can always get a tubular front crossmember, lower control arms and coil-overs that will bolt directly into your car from www.paracing.net
It'll be a lot easier than trying to adapt a suspension system from some other type of car. By the time you're done trying to fit the corvette system in, the aftermarket one would be cheaper.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Apr 30, 2001 | 10:41 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
It would be more impressive if you got the back end of the vette. IRS!! now THAT would be cool!!!
Old Apr 30, 2001 | 11:48 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I have the rear suspension out of a 77 Jag XJS, think that would be any good? LOL
Old May 1, 2001 | 11:56 PM
MasterGo8's Avatar
No one has anything to say about this? IM sure someone has done it or thought about it. Our suspension is not top of the line and I want to make it better. Help me.
Old May 2, 2001 | 12:33 AM
Tas's Avatar
Tas
um unless you want to put in whole new frame before the rear subframe, forget about it. Thats why no one is commenting. Try to get the rear though.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 2, 2001 | 08:54 AM
Kenn's Avatar
I've been thinking about it after reading Herb Adams suspension book (forgot the exact name) but more about switching from strut to upr and lwr control arm front suspension - Peerless Engineering offers software to custom design the front suspension for whatever camber gain, caster, brake antidive, roll center, etc you want by entering dimensions like track length, upr and lowr control arm pivot points, spindle info, more - of course there is a lot more to it- trying to be brief -
Theres hardly any room for an upper control arm on our cars - although according to Herb's book the upper control arm can be at least 30% (recommended range 30-80%) the length of the lower control arm so it may be possible ,look how short the 4gen upca are, but will C4 I'm assuming upca fit and give the performance characteristics you want? - theres always custom
now we need a way to mount the upper control arm to the frame which I think can be done by having an aftermarket K-mbr, a bracket extending from the mounting points of the K-mber across the hole for the springs to the outside of the frame wherein the bracket will provide a mounting point for an inner shaft that the upper control mounts to and a mount for a coil over - seems doable-
C4 spindles might work I think - it looks like they have the 1LE calipers and I believe the wheels have the same bolt spacing - may have to check backspacing and brake clearance- again there always custom spindles
what you get for the work is less weight and increased camber gain of a upr and lwr ca suspension versus the strut type - may/may not be worth it but I'll prolly keep thinking about it anyway
Old May 2, 2001 | 07:30 PM
War_Eagle's Avatar
You guys are saying to get the rear suspension from a late model vette, what year do you recomend and what parts are necessary? also any idea on price? any advise would be appeciated........
Old May 2, 2001 | 08:20 PM
Tas's Avatar
Tas
Vette IRSes usualy go for $1500. Get whatever parts you can. There was a guy that put one in but he never told anyone he did it on his GTA. I know there are 2 modles, a dana 36 and a Dana 44. a Dana 44 is about as strong as a chevy 12 bolt, and the dana 36 is less strong. I dunno if it is stronger than a chevy 10 bolt. I have a Dana 35 in my jeep and it seems almost as weak as a chevy 10 bolt.
-Tas
LT1Formula
Oct 8, 2015 08:34 PM
the_hamturdler
Sep 30, 2015 12:50 PM
