Will lowering cause chewed tires?
I want to put new springs in my car after all the trouble I have been having. I got new after market springs put in and the front ones are great put the rear is saging already and the spring rate is pathetic. It bottoms and tops out. I have tried a bunch of different shocks but it comes down to the fact that the springs suck.
I was wondering what are the highest lowering springs(sounds weird)and will the car start chewing tires because of improper camber adjustment? I also have heard that Jamex springs are not that hot. Any tips from people would be great. I have been reading past threads but I want a little more info before I decide. THANKS!
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
91 Z28 Camaro
305 TPI
Car: 82 camaro SC
If the camber adjustment isn't right, just have it corrected. The camber is adjustable and you can get it perfect on a 2 inch drop. What kind of springs did you get? Drop springs decrease suspension travel and will cause your car to bottom out more. You may want to cut the snubbers to increase suspension travel.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 82 camaro SC
I see, drop springs tend to be stiffer. Do you have alot of stuff in the back to make it sag(stereo stuff)?
82camaro
82camaro
I have a pretty heavy sub box but I take it out and there is no difference. It rides the same and the height is the same. I was just concerned that I couldn't adjust to counteract the camber. I don't mind a really stiff ride.
Car: 82 camaro SC
With a 1.5 inch drop on my 82 I can adjust from -.75 to about +1.25 degrees of camber. Lowered cars like a different alignment:
-.5 camber
+4.5 caster
-1/16 toe
works really well for a hard driven street car--even tire wear as well. I've done alot of third-gen alignments with those settings.
82camaro
-.5 camber
+4.5 caster
-1/16 toe
82camaro
Thanks 82 Camaro....you gae me a lot of good info. What springs would you recommend to give me a minimum drop. I want something that won't sag.
91 Z28 Camaro
305 TPI
91 Z28 Camaro
305 TPI
morrow
Jan 13, 2024 12:29 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
