12 bolt dif swap
Old May 20, 2001 | 10:59 PM
camarokid's Avatar
12 bolt dif swap
I have a 90 camaro RS that I am going to build up. I dont want to mickey mouse anything. I want to put in a 12 bolt rear end. What do I need to do to put it in. Is it a bolt on part, or how much custom work do I have to do. I want to keep this car all GM. NO FORD PARTS. Any help would be apperciated.
Old May 21, 2001 | 10:02 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need to buy an aftermarket bolt-in housing. Finding one in the junkyard to use is out of the question. First of all you need to find one narrow enough to fit under the car (first gen f-bodys). Moving all the mounting hardware such as shock and spring mounts over to the 12 bolt isn't hard but you'll find that trying to mount the torque arm is impossible. The only way around it is to go to ladder bars or a 4-link system and by the time you're done fabricating everything, it will be cheaper to just use the aftermarket diff.
It doesn't matter if you go to a bolt-in 12 bolt or 9". Both will set you back about $2000
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theurge
Aug 21, 2015 12:46 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
