How do you remove the rear disc calipers?!?
Old May 22, 2001 | 01:31 PM
cbpldc's Avatar
Hey all,
I will be installing new calipers and rotors on the rear of my 84 'bird. I can't get to one of the bolts to take the calipers off. Am I going to have to drop the front end? I will need a 7mm or 10mm hex head tool to remove them, correct? Also, what else will I need to do to get them to cunction correctly? I will need to bleed the brakes, right? How exactly is this done on this car? The car is an 84 Firebird S/E with rear disc brakes BTW
Thanks,
Chris
Old May 22, 2001 | 02:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Chris, did you see my "recall info" response to your message on the tech board? Here's the link: https://www.thirdgen.org/messgboard/...ML/009233.html
I used the same hex head socket for my rear calipers as the one I use for the fronts... if that helps. If you have a manual transmission and qualify for the recall, have GM do it. If you don't, you can check out that link I put on the tech board for the recall part # info, and pick up a Haynes 82-92 Firebird manual. They show a pic-by-pic rebuild of the rear calipers, and tell you how to bleed them, too.
(Hint- replace the back body-to-axle and right-rear-caliper brake hoses while you're at it!!! Now's a great time, those hoses are too old.)
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 23, 2001 | 06:24 AM
cbpldc's Avatar
TomP, thanks for the recall info. I called and the service guy says that there is no recall, just a service bulletin (I feel like I've typed that somewhere before....)
Chris
Old May 23, 2001 | 12:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, there is a TSB that details the work to be done, but I'm pretty sure about the recall. The recall is only for 4-wheel-disc f-bodies with the MANUAL trans... guys with the Automatics get nothing for free, except the TSB info.
Call another dealership...
Old May 24, 2001 | 06:30 AM
cbpldc's Avatar
That fits me to a tee. I have an 84 Firebird S/E 6 cyl, 5 speed, 4wheel disc. The guy was very helpful, but had no idea what I was talking about. Do you have a number that I can reference about the recall? I will contact another dealership this week.
Thanks,
Chris
Old May 24, 2001 | 09:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Chris, GMTech did us a favor and looked up the exact recall info back in January. Here's the link to his message:
https://www.thirdgen.org/messgboard/...ML/000738.html
Old May 24, 2001 | 09:30 AM
Metalifann's Avatar
If I have a 9-bolt rear-end from an 86 car, will GM fix it for me under the recall? Its in a 92 RS.
Old May 24, 2001 | 10:05 AM
89ragtop's Avatar
Car: 1989 Camaro Convertible
I seriously doubt GM would fix something for free on your car that was not originally installed on it.
Old May 24, 2001 | 02:45 PM
cbpldc's Avatar
I called another dealer and he said that he had no idea what I was talking about. Is there some kind of a number that I can use to reference this by?
Old May 24, 2001 | 03:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you have a manual transmission, it'll be covered under Safety Campaign 86C28. If you have an automatic, it's under service bulletin 88-450-5.
Old May 25, 2001 | 06:15 AM
cbpldc's Avatar
And the Safety campaign should get my brakes fixed for free, correct? I do have a manual tranny, J65 firebird.
Thanks so much for your help, you have no idea how big of a relief this is to me.
Chris
Old May 25, 2001 | 12:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As long as your car originally had both rear discs and a manual transmission.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
3rdgenparts
Aug 8, 2015 07:09 PM
