front brake problems! help!!!!
Old May 30, 2001 | 12:16 AM
FTC's Avatar
FTC
so here goes- started out wanting to change the front disc brakes and pads cause they were low and the passenger side made considerably more dust. replaced pads, rotors, repacked bearings, and put in new seals. drivin along and at a certain braking point the steering wheel starts shaking and the car shimmys to a stop. WTF?!?!?! went back and checked everything- bearing, pads, rotors, antiseized the bolts. i did find that the bearings made a clicking as the rotor spun and the pads didnt really let go of the discs well. any ideas on whats wrong? also checked the suspension and its pretty tight except for one tierod on pass. side. thanks for your help.
91 Z28, 64k mi.,k+ns, chip, flows, fresh black paint, gts blackouts all around, 18" chrome irocs, kybs, eiback 1" springs, global west sfcs, nu stereo/sub/amp, red dome/guage lights, and plenty more to come.
Old May 30, 2001 | 12:22 AM
Sinister's Avatar
I would recheck the bearings and the spindle to make sure that they don't have flat spots and if the left side has more dust then it's a possiblity that your right caliper might not be working correctly which could be your problem. Check the calipers and the bearing surfaces and a suggestion if you dont know when the last time you replaced the bearings it might be a good idea to do so.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
