How do you guys get traction?
Old May 24, 2001 | 01:28 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I have an 89 IROC w/ 350 TPI, 700R4, 2.77 gears w/ posi and stock TQ converter. I want to know how you guys get traction, especially you guys w/ over 400+ HP and tons of TQ. My engine is basically stock w/ full exhaust, cold-air induction, ported plenum, roller rockers, pulleys, and a chip. That's about it and I sit and spin the tires for around 2-3 full seconds. So how do you guys w/ a lot of power, 3.45-4.11 gears and a 2400 stall converter get any traction?
Old May 24, 2001 | 01:34 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
When you find out, let me know. I have over 400 ft/lbs to the wheels, and every suspension upgrade except springs/shocks and a torque arm, and I can still spin the tires thru first and second gear. My 60 foots suck!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 24, 2001 | 02:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Slicks
Old May 27, 2001 | 05:23 PM
Gta-Paladin's Avatar
Stick a fat chick on your hatch but make sure you have wheelie bars
Old May 27, 2001 | 08:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Tire choice. All the suspension modifications in the world can't help if you can't get the power to the ground.
Z rated street tires are very hard. They're designed for high speed without heating up. They're not designed for straight line accelleration.
A racing tire can be anything from a full slick to something like nitto's or MT drag radials. They are made from soft rubber that will heat up and get sticky. The downside to this traction is that the tires don't last very long.
A street tire can have a life expectency of 50,000 miles while a DOT slick may only be 3,000.
You'll have to ask yourself what you need. A long life tire or very good traction at the cost of replacing tires regularly.
My last set of slicks lasted 2 seasons and they see no street use. I'm hoping to get that out of my new set but I don't expect it.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 28, 2001 | 11:13 AM
82camaro's Avatar
Car: 82 camaro SC
Don't launch so hard(a little less throttle). LCA relocation brackets helped my launch.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 30, 2001 | 06:16 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Now when you say "don't launch so hard", do you mean you just gas the car a partial throttle to gain traction, and once you are in motion, mash the petal to the floor?
I know the TPS has to be practily mashed to the floor to get it to send the 4 volts required to the ECU so it knows to max out your cars acceleration.
Am i on the right track with what im saying? Just partial throttle untill you are in motion, then jam your petal down to get maximum acceleration once your tires have traction?
Hey, every tip counts, and i know i don't know every trick when it comes to 'performance' driving.
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
Old May 30, 2001 | 10:56 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
<font face="Verdana, Arial" size="2">Originally posted by Christos:
</font>
What I find works best is to "roll" into the gas, hit the gas fairly hard to get a good take off and steadily give it more gas.
usually, in a well tuned car (like yours) a quick throttle stab will send your tires smoking, even if you start with a bit of forward motion. Rolling into the gas give the tires more of a chance to stay hooked to pavement.
not that im an expert or anything, just what I have found that works
good luck.
Jeremy
WHO NEEDS VTECH, I HAVE VORTEC!!
1982 Camaro w/ mild L31
14.02@104mph
one legged..
Old May 31, 2001 | 01:06 PM
karstenkurtz's Avatar
My IROC is making somewhere around 450-500ft/lbs. With all these gobs of torque my tires spin like CRAZY 1st gear, 2nd gear, and even into third gear. When you figure out how to get power like that to the pavement please let me know. Mind you even without traction in a 1/4 mile or greater distance it doesn't matter you still end up spanking most cars like a $2 Hooker
Karsten
86 IROC-ZZ4... too much to list.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
aaron7
Aug 17, 2016 06:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
