did thirdgen ever come out with manual steering out of the factory?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All third gens came with power steering. You need to find a manual box from an S10/S15 that had a 4 cyl in it. It will bolt right up. You can use the S10 pitman arm but it's better to have the third gen arm installed on the manual box. The angles are slightly different.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
</font>
</font>
guestamation?
Car: 87 IROC L98
The power steering box, pump, fluid and brackets, cooler if equiped, hoses, were probably around 50 pounds. Maybe more.
A manual box is less than 10.
A manual box is less than 10.</font>
Say if I went to junk yard to get one...
what all would I need to get? just the manual box or what else....
my power steering pump is out and I've been wanting to convert over any way. It just seems like a good time.
With out da power steering pump it's still kinda hard to turn da skinnys. It would be alittle easier with the manual box wouldn't it?(since the pump is out)
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
<font face="Verdana, Arial" size="2">Originally posted by Z-BOSS:
kinda hard to turn da skinnys. It would be alittle easier with the manual box wouldn't it?(since the pump is out)</font>
Car: 87 IROC L98
Depending on what year the truck is you may need standard or metric tools. 3 (or 4) bolts hold the box to the frame. A bolt holts the slip yoke for the steering shaft. The pitman arm can be left on but you'll need to take out the cotter pin and nut for the tie rod and hammer the tie rod off.
A few wrenches, probably some sockets and a ratchet, side cutters, prybar and a hammer. I can't even guess at all the sizes. I think the mounting bolts need a 3/4" wrench and socket.
The hardest thing will be locating a 4 cyl truck first.
The steering ratio is higher because there isn't a power assist. This means having to turn the wheel more to make turns. It's how the box is geared to give torque multiplication.
I wouldn't recommend a manual box for wide 16" wheels. That's why many 16" rim cars have a quick ratio box.
I have an 86 S10, 4 cylinder with manual steering. The box looks like it bolts up the same as the one on my thirdgen. I have been wanting to convert my trucks steering to power because of the ratio of the manual steering box. All that turning gets really old really fast.
i have a manual s10 box on my car. easy swap. the frame to box bolts took a 15mm socket i think. i changed to a tilt stearing column at the same time.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 87 IROC L98
I considered changing my tilt column to a standard one but the tilt helps me get in and out of the car past the roll bar.
<font face="Verdana, Arial" size="2">Originally posted by german-motorsport:
the S 10 conver. is the easy one!!
a rack unit is in works at AJ´s , the frameconnector need to be swapped to their sys though!
anyone in here put a rack ( mustang/vette style) in his 3.gen??</font>
Most sactioning bodies impose a weight penalty for non stock type things such as steering.
so the weight i would be losing by going to a manual rack in the end really wouldn't be worth much because most places i looked, it took a .1lb weight penalty per cubic inch so i decided against it. I'm probably going to just run a manual steering box or just keep power.
[This message has been edited by 89ProchargedROC (edited June 10, 2001).]
man, this topic picked up more than I thought
86 IROC 406 tpi mass air
trickflow g2 heads
slp runners
stock tpi
about a 272 custom hyd roller comp cam
30 lb injectors
no smog,a/c,or egr
working on homemade chip
ARAP as a base setting
running on radials....
Check out my new website!
http://jackel_38610.tripod.com/wildstreetracing/
trickflow g2 heads
slp runners
stock tpi
30 lb injectors
no smog,a/c,or egr
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
I WANT A RACK AS WELL. WHO HERE KNOWS WHAT IT TAKES AND WHO IS ENGINEERING ONE TO MARKET?
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
<font face="Verdana, Arial" size="2">Originally posted by irocdaddy:
</font>
</font>
they have a kit for you but you need to get their k-member with it.
plus it is all bolt in including the rack/pinion conversion.
Call up jason or vernon and they'll tell you anything you want to know. As you can already see i almost went through with the rack conversion
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
